8 members (tclederman, Hambone, sron48, Gdads51, cmayna, dt235sd, papas52, Bruce 1954-4100),
140
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,111 Posts1,056,258 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2012 Posts: 9 New Guy | | New Guy Joined: May 2012 Posts: 9 | Just finished rebuilding and reinstalling the 235 in my '55 2nd series 3800 truck about 2 weeks ago. After a few stabs at setting the ignition timing, it fired right up using my charger. Did the cam break-in and took it for a very short drive. It ran great. The next day, I started it up with no problem without the charger and took it for another very short drive. Yesterday, it turned over extremely slowly so I hooked the charger back up. It actually dimmed the lights in the shop when I hit the stomp starter (and still turned over slowly when hooked up to the charger). It finally started, but it wasn't happy (backfiring and it seemed like it didn't have enough juice to the coil.)I couldn't keep it running long enough to get out and put a meter on the coil terminals. Both battery cables are good (.3 ohms end to end), the connections are good, the neg cable is under the upper starter mounting bolt along with the original braided ground strap which runs to the firewall. Any ideas? Thanks in advance, Dale | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Make sure you have heavy enough battery cables. Is the mounting area for the starter painted? If so you might want to clean things up so the starter can get a good ground. Does the truck spin good without the ignition turned on? | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | This is a 12 volt system, correct? I am wondering if your starter is on the way out. There are a lot of things to check out here like initial off load voltage of your battery. | | |
