4 members (mick53, 1955 1 Series, klhansen, Shade Baby), 101 guests, and 1 robot.
Topics128,113
Posts1,056,277
Members48,439
#900165 11/29/2012 8:39 PM
I had my rear axle housing powder coated. The powder coater did not mask off the flange where the cover and the carrier mount. Do I need to remove the powder coat where my gaskets will go? Thanks.
1957 3805 Panel
It's not how you fall down, but how you get back up.
shouldn't be too tough and would be a good idea, the powder might be too slick to insure a good seal even with some sealant
I would remove it from the carrier side as the extra thickness will move the carrier forwards putting the axle alignment slightly off.
It may not be a big deal but may lead to spline and axle bearing wear.
My Blog
