5 members (52Carl, GradyB, GRNHydra, Pre '68 Dave, DadsFirstPickup), 82 guests, and 1 robot.
Topics128,080
Posts1,055,944
Members48,430
#900145 11/29/2012 7:01 PM
OK, I'm in the right forum tonight,question is;found a broken ground, after the new bed was installed. A bad bulb, and ground at the parking light. Every working, KINDA. WHY is the signal lever red light on {the flasher light},and when the blinkers are on the greens don't blink? All this is going to do is kill the battery.I'm prity sure it a ground problem. HELP Paul [new bulbs and rechecked, new flasher, checked the stay cons.]
What brand of signal switch are you using?
Can't think of name, too tired to go out again, it's the pop. one and the strap is clean,collum cleaned, and tight.
