2 members (JW51, GrandpasJimmy), 88 guests, and 1 robot.
Topics128,110
Posts1,056,241
Members48,437
#900098 11/29/2012 1:36 PM
hey guys,
almost done with my 1958 235 rebuild but now for a critical question that i've been confused on since the beginning.
In 1958 235's i understand the oiling line from "point A to point B" in the lifter compartment was deleted and blocked off. The oil then is channeled through the middle of the head through the block where a head bolt is grinded to allow oil flow, into a coupler that oils the rocker shaft/arms. BUT when i tore this puppy down there was an oil line that went from the right side of the block (down in the crankcase) up and over the valve cover into the side of the head where the oil flow for the rocker arms is...why the hell would they do this? to extract overflowing oil? what is it for? and should i block that hole off on the side of the block or replace the oil line with a new one?
thanks
Sometimes the passageway in the block stops up. And a good way to insure oil flow to the rockers is to add the external line.
Both my 1958 235 had this line, and I added one to a 261 I had to make sure the rockers oiled.
With a clean fresh rebuild you should not need the external line.
Just make sure you are getting oil to the rockers when you prime the engine.
My Blog
roy could you send me a picture of your setup so i can see which hole in the block you have it plugged into exactly. any other opinions on this?
I no longer have either engine. But the cylinder head has a 1/8 inch pipe plug on the passenger side about center in the head close to where the valve cover gasket sits. The other end ties in with the oil pressure gauge.
As was said earlier, with a fresh rebuild, you shouldn't need that line. But make sure the correct head bolt is used so that the oil can flow around it to get to the rockers.
I installed one just for grins and giggles. I wanted to make sure the top end had oil. Overkill, but never had any problems.
cool, ya i looked at all the bolts and the only one that was significantly different was grinded on the side, figured that was the one.
