| | | Forums66 Topics128,109 Posts1,056,262 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#90009 04/28/2004 6:21 AM | Joined: Feb 2000 Posts: 41 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 41 | Anyone familiar with installation of the original radio in a 54 1/2 ton? Is there a bracket to hold it? Seems to be a bolt on the drivers side, but my truck doesn't seem to have anywhere to attach the bolt. Any help appreciated. | | |
#90010 05/03/2004 10:29 PM | Joined: Oct 2003 Posts: 124 Member | | Member Joined: Oct 2003 Posts: 124 | The radio in my 54 car is like you describe - bolt on right side which DOES connect to a bracket.
The bracket on the car is mounted to the firewall, with the bracket arm coming out directly toward the dash. Perhaps your's was removed - look for the bolt holes on the firewall.
These old tube radios are HEAVY and really need support. | | |
#90011 05/04/2004 2:29 AM | Joined: Jun 2001 Posts: 379 Shop Shark | | Shop Shark Joined: Jun 2001 Posts: 379 | If you can find someone with a copy of the '54 accessories installation manual, there is quite a bit of detailed instructions on how to install it. I would send you a scan, but lack the hardware. I just sent a big check to John Kerry.  | | |
