3 members (Hotrod Lincoln, Bill Hanlon, 1 invisible), 162 guests, and 3 robots.
Topics128,088
Posts1,056,113
Members48,434
I'm working on a 55 Chevy pickup and have decided to totally redo the wiring. I'm putting a 305 and R-700 auto in the truck along with a new IFS and steering column from a chevy van (hopefully) I understand i can buy entire wiring systems which come with coded wire and that each wire has a tag which tells where it goes. SO......I should tatoatlly remove all of the wiring?? Where do you recomend I go to buy a wiring kit?
Thanks.
I haven't bought mine yet but when I do I've heard a lot of good comments about Y n Z's harnesses. Chevy Duty, Jim Carter etc also sell nice harnesses. Wiring is all Y n Z does.
You might check
www.ezwiring.com
1956 Chevy 3100
261/700r4 (formerly 3 speed OD)
More pix on Photobucket
I used a painless universal kit on my 46. It was sectioned, color coded, labled and numbered. I used a 350 tranny but they also make a lock up kit for the 700R4. It wasn't the least expensive, but I was happy with it. I took the time to solder the joints instead of crimping. Just remember to put the shrink tube on first.
