0 members (),
40
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 93 | 1 yr. old new wire harnis. Every thing was working FINE on my 53, 3600 pu,but i had to change the park/signal light with led,s. Should have left it alone. Changed back to orignal lights,then no blinkers.But light stay's on, on collum. Changed flasher{was bad}and replased a bulb. Still no blinkey. Park lights o\are working. Any ideas (back lights good)did'nt check pass. side though, looked good last night, so did the bad one, need new glass's. Thanks Guy's you allways come through. Hope all had a nice Thanksgiving....Paul | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 12v or 6v? The flasher "tube" must be made for use with LEDs. The old style (non-electronic) flasher needs a certain amount of light-bulb "draw" in order to flash. Classic Parts and Chevs of the 40s sell LED flashers. | | | | | Joined: Sep 2003 Posts: 200 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 200 | Tim is correct. I have a 51, 6 volt system. I have LEDs in the rear sockets and normal lights in the front for turn signals. The normal lights produce enough resistance to work the flasher. If you use LEDs all around there is not enough resistance to work the flasher. Enjoy Mark
1951 Chevy 3100 Some days you get the bear. Some days the bear gets you.
| | | | | Joined: Sep 2008 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 93 | Tim; please check out my new post in elec,It's still a 6 volt sys. Thanks,,,,Paul | | |
