0 members (), 139 guests, and 7 robots.
Topics128,077
Posts1,056,033
Members48,433
U
Junior Member
Junior Member
U Offline
I'm in the process of tearing down a 235, '61 model year and need to remove a damaged camshaft. The repair manual lists a recommended puller tool but tried to use a Sears gear and harmonic balancer puller but the bolts and center screw does not seem to fit. Any suggestions on a home-made tool or can the old tools listed in the manual still be purchased someplance?
When Momma ain't happy, ain't nobody happy
Hey Ukon, I bought a cheap puller set at Harbor Freight for about $6 and it has served me well pulling all sorts of pulleys and the balancer on my '60 235. It is versatile enough to work on almost any size and it has a large selection of bolts to use as well. It's well worth the money and has given me not a single problem. :p
I just pulled two of them and found that i had to put pressure on the bolts to get them to thread.The rubber in them was keeping the bolts from threading.Also lubricating the threads on the puller shaft helps give you more tourqe.Perhaps you have the wrong sise bolts.Try blowing out the bolt holes,they could be full of crud.
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
The two holes in the balancer hub are tapped for 3/8-16 bolts.
Porky Pig is just a ham.
I just did mine and used a rental (free) from Autozone. I ran into your problem. The bolts would not go in. I found that the rubber inside the balancer was in the way. I kept pushing and finally threaded it in and the balancer came off nicely. - scott
55 1st Chev.
