0 members (),
54
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 16 Junior Member | | Junior Member Joined: Sep 2001 Posts: 16 | I'm in the process of tearing down a 235, '61 model year and need to remove a damaged camshaft. The repair manual lists a recommended puller tool but tried to use a Sears gear and harmonic balancer puller but the bolts and center screw does not seem to fit. Any suggestions on a home-made tool or can the old tools listed in the manual still be purchased someplance?
When Momma ain't happy, ain't nobody happy
| | | | | Joined: Mar 2001 Posts: 279 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 279 | Hey Ukon, I bought a cheap puller set at Harbor Freight for about $6 and it has served me well pulling all sorts of pulleys and the balancer on my '60 235. It is versatile enough to work on almost any size and it has a large selection of bolts to use as well. It's well worth the money and has given me not a single problem. :p | | | | | Joined: Sep 2000 Posts: 390 Shop Shark | | Shop Shark Joined: Sep 2000 Posts: 390 | I just pulled two of them and found that i had to put pressure on the bolts to get them to thread.The rubber in them was keeping the bolts from threading.Also lubricating the threads on the puller shaft helps give you more tourqe.Perhaps you have the wrong sise bolts.Try blowing out the bolt holes,they could be full of crud.
1942 1\2 Ton 1951 1\2 Ton 55 willys cj-5 1954 and 59 Cushman Scooter 1960 Biscayne Sedan 1965 G/10 panel van 1966 C/30 Grizzly Motorhome You know you're a 'Bolter when your daily driver is older than you are... My progress pics | | | | | Joined: May 2002 Posts: 20 Member | | Member Joined: May 2002 Posts: 20 | The two holes in the balancer hub are tapped for 3/8-16 bolts.
Porky Pig is just a ham.
| | | | | Joined: Mar 2002 Posts: 384 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 384 | I just did mine and used a rental (free) from Autozone. I ran into your problem. The bolts would not go in. I found that the rubber inside the balancer was in the way. I kept pushing and finally threaded it in and the balancer came off nicely. - scott
55 1st Chev.
