7 members (NJC, Gray_Ghost, GMCJammer51, Greg_H, 50Chevy3100, 1955 1 Series, 1 invisible), 74 guests, and 1 robot.
Topics128,073
Posts1,055,908
Members48,429
Greetings: Researching fabricating a removalable side window section of the burb to slide into panel truck and vice-versa. Would have two separate units all painted up to change when one felt the urge. Also will do the same to barn doors & clam shell unit.
Have the necessary items. Cannot afford two trucks. Love them both. Comments Cheers
To me, the panel is attractive with the one piece side. (no break lines)
I don't know if it would look as attractive with a "plug" in the window holes. Even if it where a one piece plug.
The factory made the plugs and such for the clamshell vs. barndoor rear doors. They are hard to find, but they are out there.$$$
All you need then is two sets of doors and the hardware to change em.
Let us see pics when you get there.
Jon S
Las Vegas NV
1966 GMC Suburban 305V6
Psalm 66 "Make a joyful noise"
http://i12.photobucket.com/albums/a205/gvdobler/0205011645b.jpg
Hi; Yes there would be some break lines alright. Would depend
on the type of joinery, some sort of overlap to hide the rubber seal.
