| | | Forums66 Topics128,050 Posts1,055,757 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#89927 07/07/2002 8:54 AM | Joined: Jun 2002 Posts: 21 Member | | Member Joined: Jun 2002 Posts: 21 | I have gotten the delco generator of my dreams, maybe. Is there a site which has delco generator part numbers? Or is there some other way to decipher the part numbers and tell if my generator is 6 or 12 volt? | | |
#89928 07/07/2002 9:18 AM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | On the Delco generators I have seen ,, the black painted oval data tag is on the 6V and the red painted tag on the 12V. | | |
#89929 07/07/2002 1:00 PM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | I have an old Delco Parts Book that lists generator numbers, their original application, and whether they are 6 or 12 volt.
If you post the number of yours, I should be able to tell you the original application..
Dusty is correct about the color of the tag..
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#89930 07/07/2002 7:21 PM | Joined: Jun 2002 Posts: 21 Member | | Member Joined: Jun 2002 Posts: 21 | I pulled the generator out of the box. It only has a rebuilders tag on it. The numbers on the rebuilders tag are:
33/1028 21/9/10/79
The reason I was impressed with this was that it has the shaft out of both ends to attach a power steering pump.
I guess that means I am SOL as far as a definite identificaton goes. | | |
#89931 07/07/2002 10:25 PM | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | Delco generators have 7 digit ID numbers. 95% of them begin with a 11..
#89932 07/15/2002 1:57 AM | Joined: Apr 2000 Posts: 71 Shop Shark | | Shop Shark Joined: Apr 2000 Posts: 71 | I don't recall any 6v Chev having power steering. I may be wrong on that, but you most likely have a 12v unit off a late 50's v-8. | | |
#89933 07/17/2002 2:33 PM | Joined: Feb 2002 Posts: 40 Member | | Member Joined: Feb 2002 Posts: 40 | I have the same question, Bill. My generator is a model 0028. Is it a six volt?
Can U believe it? My wife says: "I want an old pickup truck" so I HAD to buy it!! '50 Chevy 3100 5 window.
