| | | Forums66 Topics128,073 Posts1,055,908 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 193 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 193 | I had to take the 4 speed top loader trans out of our 55.2 3600 yesterday. The PO had installed a PTO on the side of it. I removed that cuz I didn't need it. THe parking brake handle is next to the shifter between the gas pedal and the shifter. It has a handle on it that you are supposed to squeeze to release the parking brake paw. I am not sure if the spring is weak or what, but the parking brake does not hold its position when applied. The paw does not fall down into position on the teeth bolted to the side of the trans. Here is a pic of the handle. Brake Handle Somebody else have this problem? Help? Thanks. Brian
1952 GMC model 473 dump truck 1951 Chevy 1500 stepside
