0 members (), 196 guests, and 1 robot.
Topics128,081
Posts1,056,078
Members48,434
#899136 11/25/2012 6:33 AM
Thought for sure that the rear main was leaking
but now I'm not sure. Dropped the transmission and bell housing. The rear main was dry and the oil leak appears to come from a casting plug below the head and above the crank. If I was to guess, I would think coolant and not oil would be there. Any opinions?
Bob Giles #899137 11/25/2012 6:42 AM
There is a plug right behind the end of the camshaft and if that leaks it would be oil.
1951 1 Ton Completed
