1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 11 New Guy | | New Guy Joined: Nov 2012 Posts: 11 | My 46 is pulling to the Left badly. I have adjusted the brakes, cleaned the wheel cylinders in front, replaced lines in front and replaced fluids. Master cylinder has been replaced as well as rebuilt kits on cylinders within the last ten years. Pads have plenty of life. Any other ideas? | | | | | Joined: Mar 2007 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 65 | Is it pulling during braking only or all of the time? | | | | | Joined: Nov 2012 Posts: 11 New Guy | | New Guy Joined: Nov 2012 Posts: 11 | | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | Both drums are the same diameter? Hoses are good? Tires are good? | | | | | Joined: Nov 2012 Posts: 11 New Guy | | New Guy Joined: Nov 2012 Posts: 11 | Yes, the same diameter. I replaced the hoses. Was tracking fine before I let it sit for a year while working on the body. I thought maybe the fluid had gummed up the cylinder and hoses, so I cleaned the cylinder and replaced the hoses. Also adjusted the shoes several times. I assumed that maybe the passenger side brake was at fault but can't find anything. I'm lost now. Tires are brand new. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Oldschooldude, Have you checked the rears as well? If you have two brakes working on one side of the vehicle, and only one working on the other side of the vehicle, you'll get a pull to the side with two functioning brakes, hope that helps. | | | | | Joined: Nov 2012 Posts: 11 New Guy | | New Guy Joined: Nov 2012 Posts: 11 | Thanks. I thought of that and will be checking the rears in the morning. While there, I will replace the lines as well as cleaning the wheel cylinders. | | | | | Joined: Mar 2007 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 65 | You may want to also check out the linings and drums. Had rear wheel seals leak a lot of rear end 90w into the drums. Once I got the rear seal problem fixed and drums and linings cleaned, the brakes were much better. No pulling to either side after that either. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Was there any sign of leaking on the front brakes when you pulled it apart? If any fluid has leaked on the shoes it will pull, even if cleaned. In my experience rears do not cause much of a pulling problem. You may still have air in the system.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Nov 2012 Posts: 11 New Guy | | New Guy Joined: Nov 2012 Posts: 11 | There were no signs of leaks on the front. The wheel cylinders had rust and appeared to have a little moisture . Cleaned them up. Did not see anything on the pads or drums. | | | | | Joined: Nov 2012 Posts: 11 New Guy | | New Guy Joined: Nov 2012 Posts: 11 | What did you use to clean the drums? | | |
