8 members (Oldcaliforniakid, Otto Skorzeny, jmoore, frogfarmer, Hotrod Lincoln, 49nut, Stovebolt48, mason86), 114 guests, and 0 robots.
Topics128,050
Posts1,055,671
does anyone know where to get GOOD replacement gauges for a 53 3100. If I have to pull that dash apart one more time I'm going to have an aneurism.
links
parts
brokenhead #898909 11/24/2012 10:42 AM
stock looking or aftermarket?
daren
1952 GMC 1-Ton
1946 plymouth
1947 ford
custom builder
http://www.doublegcustoms.com
brokenhead #898922 11/24/2012 11:30 AM
stock. I would just as soon have the original style, I.E. mechanical gauges. But at this point I don't really care, my neck is killing me.
brokenhead #898941 11/24/2012 12:33 PM
brokenhead #898963 11/24/2012 2:10 PM
Those are the ones I am talking about.
brokenhead #901750 12/06/2012 10:29 PM
I am looking at getting a 1937 fuel gauge 12V. Source? I would like to have all the gauges working on 12v, if possible. the $400+ kinda scares me. Do those 12v to 6v reducers work?
brokenhead #901762 12/06/2012 11:02 PM
David, just use a voltage reducer feeding the fuel gauge. Mine has a big resister and has worked for years this way. Runtz is another option, its a vltage reducer. The sending unit doesn't care what voltage is coming at it.
brokenhead #901797 12/07/2012 6:18 AM
as far as the temp gauges are concerned, I did pick up a working unit. But all the vendors carry the same gauges, which is counter parts brand. So far I have had two temp gauges, one didn't work period, the second had a bourdon tube so big it hit the reflector inside the gauge panel, and made the needle stick straight up. The oil pressure gauge had a leak at the bourdon tube. So 3 of the 4 were useless, and I am not sure of the second oil pressure gauge yet. All that being said, Jim Carter will rebuild at least the temp gauge for $115, which given the trouble I have had with the reproduction units at $80, is quite a bargain in my opinion.
brokenhead #901808 12/07/2012 7:52 AM
this was posted on the HAMB recently
...link...
Sometimes NOS temp gauges are on Ebay.
I had a square boss on a repo oil gauge snap off. very poor quality
Joe H #901856 12/07/2012 10:44 AM
thank you for the advice. My gage was hooked up on 12v, so I am not sure it is in working order. I will check that out first, then the resistor try.
I've used a CVR (constant voltage reducer) from Ford Mustangs and early Ford cars to reduce the voltage to the fuel gauge on some of my builds. They work fine and are available at all the parts stores or your local junk yard. Just got one from Pull-a-Part for $2.00.
This proud Veteran says there's nothin' like American Steel!
