| | | Forums66 Topics128,264 Posts1,058,350 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#89886 02/29/2004 9:17 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Lately I've noticed that I'm getting a shock from my door when I turn off the engine and get out of my truck.
Bad ground, right?
How do I locate it???
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
#89887 02/29/2004 3:28 PM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | bad seat cover! try putting yer hand on the door metal or handle before ya move yer [censored] on the seat, or get rid of the polyester pants [or shirts] seriously - not an electrical problem! Bill | | |
#89888 02/29/2004 3:34 PM | Joined: Jan 2001 Posts: 332 Big Bolt Shop Curmudgeon | | Big Bolt Shop Curmudgeon Joined: Jan 2001 Posts: 332 | Some more information may help.
Truck? Grounding--pos or neg.?
This is strange, because the frame, cab body, doors, engine block, and everything else should be common to the ground. When you touch any part of the metal, you are the same potential as the truck ground and shouldn't be feeling anything!
Does this occur when you touch the door or some other metal part of the truck while sitting in the truck, standing on the running board or standing on the ground beside the truck?
Does it occur when you touch the door only, or if you touch some other metal part of the truck?
You said it occurs when you turn the ignition off and get out of the truck. What about it you shut the engine down, but leave the ignition on and get out or touch metal. Does it happen then?
Does your battery discharge at all?
One starting point would be to disconnect the positive (or "hot") battery cable. Make sure that eliminates the problem. Then with the battery cable once again disconnected, disconnect the wire to the ignition switch, but leave the primary cable connected to the starter switch (on a stomper starter) or to the solenoid (on a solenoid activated starter).
Tell us more.
Drivin' down a 2 lane country road in a stovebolt.....cowboy, it don't get no better than this!
1946 1-1/2 ton Chevy "Ol Blue", or "THE BIG 'UN"
#89889 02/29/2004 3:45 PM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Glenn - maybe my answer not clear enuff? it's called static discharge, caused by cheap worn seat cover and clothes of synthetic materials - been there, done that!! Bill | | |
#89890 02/29/2004 5:25 PM | Joined: Jan 2001 Posts: 332 Big Bolt Shop Curmudgeon | | Big Bolt Shop Curmudgeon Joined: Jan 2001 Posts: 332 | Squeeze, you are correct about static discharge. I've lived in dry climates all over and am very familiar with that.
I know, too, that loose electrons running around where nobody expects them can be a problem. I also learned a long time ago to never say "never."
#89891 03/01/2004 11:00 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Glenn wrote: You said it occurs when you turn the ignition off and get out of the truck. What about it you shut the engine down, but leave the ignition on and get out or touch metal. Does it happen then? Does your battery discharge at all? ------------------------------------ No on both counts, Glenn. It's static! I'm gonna buy a couple of grounding straps today and install them. PS - This can be very dangerous when you're filling up your gas tank!!! Check this Out And This ...
#89892 03/01/2004 3:48 PM | Joined: Feb 2004 Posts: 28 Member | | Member Joined: Feb 2004 Posts: 28 | Putting a static discharge ground strap on the vehical will eliminate the problem, they connect to the frame and drag on the ground, some body shops use them when they paint vehicals to discharge static that a vehical builds up during painting so dust isn't attracted, you can buy them in most parts stores, there quite a popular part with the import crowd, although thats more for looks than funtion. Stay away from the bright reflective ones if you don't want your truck to look like every "tricked" out civic :rolleyes: | | |
#89893 03/01/2004 7:07 PM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Thanks, bro' ... I went to 3 different parts stores today and NO ONE has 'em!
What's the deal? One guy told me they are just rubber strips attached to the frame; drag on the ground. I can't for the life of me imagine rubber doing anything!!! Does that really work? He told me to just go to Home Depot and buy some squeegee refill strips.
Yes???
#89894 03/01/2004 7:33 PM | Joined: Jan 2002 Posts: 2,853 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,853 | If you had a spotlight on your truck, you can shoot them bad ole static chargers right up to the stars. Alan, Wow I have never heard of this problem before. How about putting on a pair of levi's and put a temp cover on the seat. Then try to get out without having the hairs on the back of your neck standup. Seriously for now I wouldn't drive that Red puppy too much until you get this resolved. I just don't see why you would need to install a static strap or chain. I have never seen one on our trucks. Hope all is well.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#89895 03/01/2004 9:43 PM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Maybe it's the rugs I just put in. This never happened before ... then I got two rug mats from my sister for my birthday last month and that's when this started happening. I wonder what on earth these rugs are made of. I'm gonna throw the rug-mat over on the pasenger side and take a ride ... if it stops the static, I'll just get rid of those Satanic rugs! Then I'll go get some that don't have any synthetic Satanic fibers and skip the anti-static strips that NO ONE sells!
#89896 03/02/2004 4:16 AM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | glad ya got it figgered out, Alan - didn't think you had discovered a new stovebolt electrical problem - just like when ya walk on the wrong kinda carpet w/ certain shoes on and get a zap next doorknob ya touch - only thing I've had cause it in the truck tho' was a sleezy seat cover and Craig, back "in the day" those hangin ground straps were pretty common, car and truck - when polyester was king Bill | | |
#89897 03/02/2004 4:21 AM | Joined: Jan 2001 Posts: 198 Member | | Member Joined: Jan 2001 Posts: 198 | there what a program on myth busters the other day, about cell phones and gas stations fires at the pumps, it turm out that 80% more fires occour with women then men, it seams that the silk panties, and polester seats seem to be a problem. Older persons hold on to the door frame discharging themselves, but most of us just slide across the set and hop out without touching anything, till we touch the filler pipe and ignite the gas fumes, causing a fire. | | |
#89898 03/02/2004 4:33 AM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | yeah  I maintained the computerized cash registers at a big restaurant here w/ "dress code" for staff - I had to put an anti-static mat down in front of each register, cuz it didn't work to tell the girls no panty hose on the job!  they'd run up to punch an order and you could see the sparks fly from their fingertips into the keyboard - major hicup in the puter memory! Bill | | |
#89899 03/02/2004 4:46 AM | Joined: Jan 2002 Posts: 2,853 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,853 | MT, Does that mean we need to quit wear silk panties when driving our trucks? I'm distraught over this issue.
#89900 03/03/2004 2:47 AM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Yes, down with panties!
Here's something neat to try. A flourescent tube will emit weak light if you hold it by the glass with hands spread apart and shuffle across a carpet if conditions are right for static buildup. You'll have to be in a dark room to see it. | | |
#89901 03/03/2004 4:32 PM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | I tried it without the rug-mats ... no go ... same thing. Here ya go! 12" and 18" Anti Static Straps : Click Here! " It is made of a carbon empregnated rubber which can withstand 120,000 Volts of static electricity! It is warranted for 100,000 Miles!"Also, someone said to treat the rug (or seat) with some fabric softener ... THAT eliminates the Panty Hose Syndrome.
#89902 03/04/2004 9:26 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Higher quality tires work, too. High graphite tires conduct electricity and discharge the static. The cheap long wearing 80,000 mile tires don't have enough graphite to dissipate the charge.
#89903 03/05/2004 1:02 AM | Joined: Jan 2001 Posts: 198 Member | | Member Joined: Jan 2001 Posts: 198 | The problem may not be the truck building up the the static charge, but you. When you slide across the seat and jump out, you have charged up yourself, and the next thing you touch you get zapped. | | |
#89904 03/05/2004 3:56 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | I never knew about tires ... I've got nice Coopers on.
But I think it's ME, because it's only started a few weeks ago when I put these new rug mats in.
#89905 03/05/2004 4:31 AM | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Alan - try what I said - reach over and grab the door - open it and don't let go as you turn and get out - when your on the ground, let go - next time you touch it there'll be no shock - ie: you need to be grounded when you're moving, not the truck! Bill | | |
#89906 03/08/2004 12:25 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Hey, Bill I tried it and it's works! Like magic!
