0 members (),
108
0
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 2 New Guy | | New Guy Joined: Nov 2012 Posts: 2 | so I read a thread regarding removing the exhaust manifold alignment studs with vice grips and was considering doing this myself. I was just looking for confirmation if this is possible with vice grips. thx | | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | If you mean the end studs on the cylinder head, yes you can. Depending on their condition and rust, you may need to use a penetrating oil or even apllied heat to get them out.
Drew
| | | | | Joined: Nov 2012 Posts: 2 New Guy | | New Guy Joined: Nov 2012 Posts: 2 | Thanks alot, will add another tick on the 2 do list | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | I would get a stud remover. Check out the link. I used torch and remover with PB Blaster. I heated up the stud, while still hot sprayed on Blaster.... careful not to ignite. Use a steady pressure, but don't force it or you will snap it. Use the torch on and off until loose. http://www.harborfreight.com/1-2-half-inch-drive-stud-extractor-94640.html A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | |
