| | | Forums66 Topics128,077 Posts1,056,032 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 75 | Looking for pictures of someone who's restored a Pu to stock condition or has a unrestored one I have a 41 1/2 ton AK built in Oakland Ca. Or someone in southern Calif. that i could look at there truck or ask them some questions
Thanks David
VCCA member | | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Crash2012,
I am in the process of restoring a 1941 G4112 YP model 1 1/2 ton Chevy. I can help you with some cab related questions as they are basically the same as 1/2 ton trucks. | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | You need to look at this http://www.46chevytruck.com I have used this lots, I hope my 41 looks close to this good when I'm done. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | I have a restored '41 3/4 ton.
Most is the same as a 1/2 ton. You can ask most any guestions here and get good answers | | | | | Joined: Mar 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 75 | Ok I'll check the pic's out, and I'll definatly be asking questions Thanks | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | I have a 46 1/2 ton all restored except for paint and wheels and other small modifications that arent really noticeable like no front bumper....[IMG] http://i629.photobucket.com/albums/uu14/kurtdh519/002-1.jpg[/IMG].... the 41 and the 46 are the exact same truck, mine was #1873 off the line in 1946 according to the vin #
| | | | | Joined: Nov 2012 Posts: 96 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 96 | the unit numbers started with 1001 at each plant
| | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | 41 and 46 are ALMOST exact, not quite. 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Apr 2004 Posts: 5,074 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,074 | Take a look at this Tech Tip that was put together by Kip Bonds with contributions from Stovebolters. It should help some. Peggy
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | | | | Joined: Mar 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 75 | Nice truck hoozat, Thanks peggy for the tech tip page, all the 41 stuff matched up except for the one piece headliner( mine is two) I learned that the reason the lock was in the passenger door handle only was that you let the passenger(lady) in first then she would reach across and open your door, my mom said there was a saying that if the girl hesitated to open your door she did'nt like you Thanks again | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Crash, that is a nice story but more likely; people were supposed to enter the car or truck from the curb side and not the street side. For a while cars did not have opening doors on the driver's side, only the curb side | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Kip, while I thought that for a long time too, i noticed recently that while trucks in these years only had one lock on the passenger side, GM cars (46 and up at least) had locks on both sides. I'm not sure why cars would be different. | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | 46:
I was referring to cars built in the teens and early 20's that only had doors on the passenger side. I'm not sure when the various companies started putting doors on both sides. I'm also not sure when external door locks were put on both sides.
A wild guess on why cars may have had locks on both sides before trucks could be that taller truck cabs made it easier to slide across the seat. | | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | Let me know what you are looking for. I also have a 1/2 ton original suburban carryall that can also be used as reference. Tim www.46chevytruck.com
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | | | | Joined: Mar 2012 Posts: 75 Shop Shark | | Shop Shark Joined: Mar 2012 Posts: 75 | Thanks kip did'nt know that about entering from curb maybe cars started to have both cause there was starting to be more houses with garages being built,just a thought.. Sheridan= great pic's and alot of info which is perfect for me cause I'm tring to learn as much as I can about my truck, I'm picking up NOS parts right now as I find them Thanks again all
VCCA member | | |
