1 members (Otto Skorzeny),
98
Mod | | | Forums66 Topics128,089 Posts1,056,442 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 4 New Guy | | New Guy Joined: Mar 2012 Posts: 4 | I would like to use the stock gauges in a 1950 Chevy 3100. Everything they attach to will be different. Will they work? what does it take to make them work?
I have the dash apart while doing other things and could rebuild the guages but I don't want to waste the time and money if they will not work.
The speedo will be driven by a 700R4 auto trans. The fuel gauge will read the sender in a fuel tank from a 2000 S-10. The engine temp sender and oil pressure sender will be in a 350 Chevy engine. The whole electrical system will be 12 volt and I would prefer a volt gauge over an amp gauge.
Are most of these things doable without a big hassle or expense or should I just start thinking about how to mount new gauges?
Any knowledge or experience would be appreciated.
Mods, feel free to move this to interiors or electrical if that is more appropriate. I just thought the readers of this section would have more experience in keeping the old gauges with modern components if it is possible.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What is the year/make/model of truck you are referring to - the one in which the gauges will reside?
| | | | | Joined: Mar 2012 Posts: 4 New Guy | | New Guy Joined: Mar 2012 Posts: 4 | | | | | | Joined: Oct 2005 Posts: 4,254 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,254 | | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | In a 1950 the ONLY gauge you have to do anything with is the gas gauge. The oil pressure and temp gauges are mechanical so they don't care what engine they're hooked to although you would probably want to swap out the 15# oil pressure gauge for a 60# one. You can drill and tap the left rear coolant runner for a temp sender fitting to keep the 1950 sender stock or send it off to Carter for a longer capillary tube to reach the factory sender hole in the V8 intake and/or head. Amps are amps, 6v or 12v so the factory gauge is fine. A universal tank sender for the fuel gauge can be used, 30-90 ohms IIRC but check on this. A Runtz resistor on the voltage side of the gas gauge and every gauge will work like it's 1950 again. If your transmission has a mechanical speedometer gear then the cable is a direct bolt up. If electonic someone else will have to jump in with advice. I test drive one with a gps stuck to the windshield and compare the speedo reading with the gps and figure the percentage it's off and then pick a set of drive/driven gears that will correct it. If you are going to have a lot of accessories I suggest you run a wire from the ACC terminal on the ignition switch to an auxillary fuse box because it gets crowded with just one terminal to hook to. If you're really loading it with power everything, especially an electric fan, then run a wire from the switch to a relay that has a 12g or 10g wire from the battery through the relay to the fuse block. I like one with working factory gauges over ones with round ones hung everywhere and it's so easy to do.
Evan
| | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Or you can make up a shunt and run just enough through the gauge for a reading rather than carry the entire current. His first sentence states, "I would like to use the stock gauges". If not, then disregard all of first response.
Evan
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Good to have options, he may want stock appearing and better functioning gauges.
If the question is simply will stock gauges work the answer is yes. There's usually more to the question though, and most of the time if were changing things already we want things to work better. With choices the original poster can, research, evaluate, and decide. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Nobody should run an old ammeter, they are a fire waiting to happen. Some old ideas in old things are not good ideas. Buy an old house and keep the galvanized pipes and old exposed wiring with no ground and park the truck with the ammeter in the garage and see what burns or floods first. Voltmeter is just fine, you can find gauges that look original and are much more accurate. Don't count on the speedo working just because it "bolts up". Don't count on the other/new senders to work with the old gauges unless you buy a bunch of electrical resisitors and such and try a bunch of options and spend alot of money. The 2000 S-10 sender needs a gauge that reads whatever ohms an S-10 gauge needs. Electrical oil and temp gauges are better and don't leak. We all want to use the old gauges so that we don't have one of those gauge clusters hanging down and to be more original. Install original looking gauges into the old dash cluster and that should satisfy.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2008 Posts: 133 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 133 | updated mine in the 52 to Omega gauges. after 200 miles i like them. got mine from speedway.cost w/ shipping was $474. best part for me was the electric speedo. i ran for years without a speedo and it is nice to have it back. btw i run a ford 302 and c4 trans. in my gmc(yea,I KNOW), no problems with the hookup.
daren
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | A ford engine in a sacred GMC Truck? No firewall issues because the distributor is in the front? How do you sleep at night?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2008 Posts: 133 Shop Shark | | Shop Shark Joined: Apr 2008 Posts: 133 | i sleep well thanx. the engine was priced right-free.the original was shot. it's ok i have a chevy in my plymouth.
daren | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Warning! Off topic. You are cool. Even "The Most Interesting Man in The World" hasn't done that yet! I would do that too if it was free.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2012 Posts: 4 New Guy | | New Guy Joined: Mar 2012 Posts: 4 | Lots of good options. Just what I was looking for. I wish I had the skills and equipment that some of you do. Nice work. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I too am/was a mechanical designer as I see you are. I know you have the common sense to figure things out. I found out that after I read up on something, ask the guys here, search the internet, I just dive in and do it. We all make mistakes and have to fix them, but it keeps us out of the bars. Not too many tools needed for many jobs. Just tinker and dinker. Basically the fun is in the doing and fixing the old trucks the way you want them and sit back and look at what you've done. It's not economically feasible to have all the work hired out for most of us. These old trucks are easy to work on and are forgiving with their straight forward design of all components. No electronics just electrics, no power accessories except if you add them, no fuel injection circuit, no MacPherson struts, rear wheel drive, No metric hardware and enough height that we can crawl under them. So dig in and you will develop the "skills". Everything you can ask about on here has several experienced guys who have done it and will help. Take the varied opinions/know-how and decide what to do from that.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Apr 2011 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2011 Posts: 181 | I'm running a full set of '32 Chevy gauges and use the old Speedo too. I even have the original lamp bulbs in use too. Normbc9 | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | With what engine and fuel tank sender?
