1 members (TUTS 59),
45
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,009 Posts1,055,296 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#89829 02/29/2004 4:06 PM | Joined: Jul 2003 Posts: 28 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 28 | In my '63 I have a 4spd Muncie with a Hurst shifter. I am looking for a plunger type switch to activate my reverse lights when the shifter is engaged in reverse. I found that the brake light switch is perfect for this application in regards to physical size, but when the plunger is depressed , it breaks the contact and turns out the reverse lights, instead of making the connection and turning them on. Is there anything similar to this switch out there that is a normally open switch as opposed to this normally closed swith? | | |
#89830 02/29/2004 6:57 PM | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | Some brake light switches have an extra set of contacts used in the cruise control system, and I believe they're normally-open, closed when the switch is depressed. A simpler method would be to go to an industrial electricity supply store,(W.W. Grainger is a good one) and look at their selection of "microswitch" products. They come in several shapes and plunger types, and most include a "common" terminal, and nrmally-open and normally-closed contacts. I used a lot of these types of switches when I was an industrial maintenence technician, and they've got a lot of automotive applications. Jerry
#89831 03/01/2004 1:40 AM | Joined: Jan 1970 Posts: 365 Shop Shark | | Shop Shark Joined: Jan 1970 Posts: 365 | If the brake light switch fits the mounting location and you cannot find an acceptable switch, you can still use it. You only need to add a relay with normally open and normally closed contacts. John Deere uses one in their MFWD circuit on 55 series tractors. I can get you a part number if you like--I don't have it in front of me at present. This relay is made by either Hella or Bosch.
Anyway, when the reverse lever actuates the plunger on the brake light switch, it opens the contacts. Hook up the relay so that the light power source wire goes to the #30 terminal and the wire going to the lights is attached to the #87a terminal(normally closed). Feed the brake switch from ignition switched 12 volts and have the switched wire feed the #85 terminal on the relay. Ground the #86 terminal and you are set.
A relay, especially one with normally open and normally closed contacts, is a very useful electrical component. | | |
#89832 04/18/2004 1:11 PM | Joined: Jul 2003 Posts: 28 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 28 | Thanks for your advice and suggestions. I picked up a brake light switch for a vehicle with cruise control , the kind with the extra contact , and now everything works like I want it to. | | |
#89833 05/04/2004 2:49 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Greg63, I'm installing a reverse switch into my SM420 tranny. When the plunger is depressed, the circuit closes sending voltage to the lamps. The switch is Napa's # NS119.
I actually haven't physically installed it yet, only mentally. Need to find time.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
