Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (thekid1950, baldeagle, Steelonsteel, cmayna, Rusty Rod, 78buckshot), 50 guests, and 2 robots.
Topics128,006
Posts1,055,268
Members48,418
#897183 11/16/2012 7:33 PM
on my 1958 powerglide the tranny shifts a little too late i think , it shifts around 35 mph, by my speedo , is that normal ??? it down shifts just fine , i have checked the fluid ,its fine, somone fill me in please
thanks
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #897186 11/16/2012 7:46 PM
Do you have 2-speed Powerglide, which I do not see listed in the 1958 truck specification manual (but was available in later years), or do you have the 6-speed Powermatic that was available in 1958 trucks?
What color ID plate (and ID code) is on the transmission?
lilrobo #897190 11/16/2012 7:56 PM
Yes its a 2 speed
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #897196 11/16/2012 8:11 PM
Accarding to the '59/60 Suppliment, the upshift points w/235 and 3.36 axle are; Throttle Closed 12-15 mph, Detent Touch 27-44 mph, Through Detent 44-49 mph.
Bill Burmeister
lilrobo #897211 11/16/2012 8:58 PM
Sorry i dont undersand all that
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #897233 11/16/2012 10:16 PM
At engine idle it will up shift from 12-15 mph
moderat throttle opening will upshift from 27-44 mph
At WOT (full throttle) it will upshift from 44-49 mph
That is all with stock 3.38 axle ration & tires that are the same rolling circunfrence as stock.
BC
1960 C60 pasture art
lilrobo #897280 11/17/2012 6:47 AM
Ohh ok i see now thanks, , moderat throttle 27-44 seems high 44,wow maybe mine is right on then, ,is there a way to chang it?
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #897313 11/17/2012 9:47 AM
Change the length of the throttle linkage from the carburetor to the transmission. I don't recall which way to move it, but lengthening the linkage will move the shift point up or down, and shortening it will have the opposite effect. DO NOT GO FOR AN EXTREMELY SOFT SHIFT! It will cause the clutches to slip and burn. A powerglide has two shift speeds- - - -too low and too high!
lilrobo #897819 11/19/2012 11:05 AM
Because a powerglide is essentially missing first gear compared to a 3-speed, don't concern yourself with it shifting too high. As long as it shifts well and isn't over-revving the motor it's not a big deal.
My 46 GMC on Photobucket
lilrobo #897835 11/19/2012 12:34 PM
thats what i am affraid of ,, seems to me it should shift sooner ,, but could be me , i drove it all weekend and seems like i could play with gas and make it shift sommer , by revving it and when i want it to shift just let off a tiny bit , or anyway seems like ,,,
thanks
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #897851 11/19/2012 4:43 PM
I always thought the PG basically missed 2nd gear. That's why the waited a bit later to shift.
Either way, they do delay shifting a bit longer than most automatics.
lilrobo #897955 11/20/2012 2:33 AM
Sounds as if it could be operating as designed. It's a big jump from lo to direct, if it shifts upshifts any sooner it will have to downshift again with just a slight load or throttle increase. Every Power glide I've ever driven sounded like a s screaming jet right before WOT upshift.
BC
BC59 #898137 11/20/2012 9:56 PM
Thanks good to hear,, i was hoping it wasnt bad,
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
