8 members (Bill Hanlon, Waveski, Jon G, Pre '68 Dave, 3B, kades51, 2 invisible),
126
Mod | | | Forums66 Topics128,283 Posts1,058,513 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 29 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 29 | Hi everyone. Will a 1962 chevy 235 truck engine fit in a second series 1955 truck? Will it bolt right in without any modifications? Thanks. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | A 62 engine will not have the needed front side mount provisions. Only 1955 2nd-1959 have the mounting bosses. You would need to use the center side mounts with a new crossmember. I can't remember if the 55 2nd series uses the front or rear throttle position on the block but the front position was dropped in 1960.
See the USA in your vintage Chevrolet! My Blog | | |
