Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (WICruiser, Joe H), 148 guests, and 5 robots.
Topics128,283
Posts1,058,513
Members48,490
#897936 11/19/2012 11:21 PM
Hi everyone. Will a 1962 chevy 235 truck engine fit in a second series 1955 truck? Will it bolt right in without any modifications? Thanks.
matt55 #897952 11/20/2012 1:55 AM
A 62 engine will not have the needed front side mount provisions.
Only 1955 2nd-1959 have the mounting bosses.
You would need to use the center side mounts with a new crossmember.
I can't remember if the 55 2nd series uses the front or rear throttle position on the block but the front position was dropped in 1960.
My Blog
