6 members (55shaker, RdsLessTaken, Gdads51, Stewart2, Steelonsteel, Otto Skorzeny), 104 guests, and 3 robots.
Topics128,165
Posts1,057,010
Members48,458
does anyone have a picture of the springs that connect to the frame brkt and the clutch/brake pedals. I believe I have them but not sure which spring goes where. I know that there is a rod that connects to the brake spring and pedal.
Dave
oldburbs #898070 11/20/2012 5:56 PM
Anybody have a 1/2 pickup??? These springs should be the same. ANYONE???????
oldburbs #898074 11/20/2012 6:11 PM
DADS50 #898086 11/20/2012 7:32 PM
Gus's pix = 5,000 words!
Verbal descriptions and diagrams:
CLUTCH PEDAL PULL BACK SPRING
27-54 MPC Group 0.844, #3653144 (6" length X 50 coils)
47-54 FAM Sect 6, Sheet 4.00
BRAKE PEDAL PULL BACK SPRING
MPC Group 4.827, #3698665 (30 coils, 5" free length)
FAM Sect 5, Sheet 2.00
BRAKE PEDAL PULL BACK SPRING EXTENSION
MPC ?
#3683931
- Lonnie
My '54 3104
LonnieC #898174 11/20/2012 11:17 PM
Lonnie What is 27 MPC group? I have the FAM manual but the clutch spring Looks different then the clutch spring that I have. Mine is 6 7/8" long X 3/4' dia. The free length of tha actual coils(50) is 5 1/2" long. It looks to be a very strong spring. I also have a 50 coil spring that is 9 3/4" long overall, with 4 3/4" of free coils. Which do you think may be the right one?
Thanks to you and Dads 50 for the help!!!!!
Dave
oldburbs #898281 11/21/2012 11:13 AM
oldburbs -
I appologize for the shorthand. "MPC" is the Master Parts Catalog - available on line at Keith Hardy' site.
> Old Online Chevy Manuals
> '29-'54 MPC
> '29-'57 MPC
Brake Pull Back Spring Description
(FYI - 4.827 #369935 is parking brake pull back spring)
> MPC Group 4.827, part #3698665
Clutch Pedal Pull Back Spring Description
> MPC Group 0.844, part #3653114
> Clutch Pedal Diagram in MPC
>> I'm not sure what springs you have. The photos by DADS50 match the Factory Assembly Manual diagrams. I defer to him regarding which of your springs would be correct for each job. I assume that the spring with the stronger pull would be for the clutch pedal.
Aftermarket springs are probably not exactly correct. I replaced the brake pedal return spring on my '54 with one from Chevs of the 40s. Chevs of the 40s often uses the same part number as the MPC (#3698665). The Chevs spring is 5-3/4" overall length, it has 50 coils, is 1/2" ID, and the hooks on each end are 1" from the coils. The spring that I replaced was stretched and distorted and I don't know if was original. It had 27 coils (30?), the hook on one end was 3-3/4" from the coils, and the hook on the other end was 7/8" from the coils. It looked like the brake spring in FAM 5/2.00, but not like the one in FAM 6/4.00. I don't know the correct length of the "Brake Link" in FAM 6/4.00 and the "3683931 EXTENSION" in FAM 5/2.00.
> Chevs #3698665
Chevs of the 40s spring #3653114 (the clutch pedal pull back spring in the MPC) is listed as Throwout Arm Spring, 6" in Chevs catalog and does not look like the spring in the FAM or the one in Gus's photos. The spring on my '54 clutch pedal is like the Chevs of the 40s spring, and it works fine.
> Chevs #3653114
The Filling Station "CLUTCH PEDAL RETURN SPRING" #SA-187 looks like the one in the FAM
> Filling Station #SA-187
The Filling Station does not show a "Brake Pedal Return Spring."
Guess I totally muddied up the waters!
- Lonnie
My '54 3104
here is my clutch return spring
...pic...
Dads 50;
I'm sorry, but I don't know your name. However, I want to thank you very much for sending the pic of the clutch spring. Thats exactly what I needed. Would you happen to have a pic of the brake spring too?I know it gets an extending rod that goes between the spring and brake pedal. this is so much appreciated.
Can I tell you how much I appreciate what you've done in carrying on in your fathers footsteps by preserving his pickup. I KNOW HE WOULD BE VERY PROUD!!!!
Again thank you for your help.
Dave (oldburbs)
Thank you for your comments, I appreciate it.
This forum is full of helpful people.It is truly a great site.
here is my brake spring
...brake spring pic...
...brake and return rod...
...pic...
...pic...
these are what I found on the truck. Do not know if it factory correct.
Thanks again!!! appreciate it
Dave
