4 members (1955 1 Series, mason86, moparguy, MNSmith), 103 guests, and 1 robot.
Topics128,068
Posts1,055,883
Members48,428
#897844 11/19/2012 3:47 PM
Before I guess at the size, what is the bolt size that is in the damper. I believe it to be
3/8 X 24. I want to chase the threads before I attempt to pull it off.
Then, I want to drill and thread the crank. What would be the proper size?
That would be for a 235.
I'm pretty sure the tapped holes in the hub are coarse threads (3/8"-16). Those who drill/tap the crank usually use a SBC bolt which is 1/2"-20 (fine thread) however I believe it's unnecessary unless the hub I.D. is worn enough that it want's to fall off. Warming it on a stove for a bit makes installation much easier.
You Tube
7/16 Fine is what they use on small blocks and 1/2 on big blocks, 7/16 fine is all you need.
http://s1055.photobucket.com/user/baldybenny/library/
1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
I have a new damper re-done with a double pulley that I want to install.
H Online: Content
I have a drill/tap guide setup for threading the crankshaft that's available for loan if you're interested. The crankshaft center bolt size is 7/16-20, same as a small block V-8. Drop me a pm if you're interested in the tooling. I believe the puller holes in the damper are 3/8-16, but I'll be glad to confirm that in the morning when there's some light in the storage shed.
3/8-16
