| | | Forums66 Topics128,068 Posts1,055,880 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 75 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 75 | Before I guess at the size, what is the bolt size that is in the damper. I believe it to be 3/8 X 24. I want to chase the threads before I attempt to pull it off. Then, I want to drill and thread the crank. What would be the proper size? | | | | | Joined: Jan 2005 Posts: 75 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 75 | | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | I'm pretty sure the tapped holes in the hub are coarse threads (3/8"-16). Those who drill/tap the crank usually use a SBC bolt which is 1/2"-20 (fine thread) however I believe it's unnecessary unless the hub I.D. is worn enough that it want's to fall off. Warming it on a stove for a bit makes installation much easier.
1952 1300 Canadian 1/2 ton restomod You Tube | | | | | Joined: Aug 2012 Posts: 402 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 402 | 7/16 Fine is what they use on small blocks and 1/2 on big blocks, 7/16 fine is all you need. http://s1055.photobucket.com/user/baldybenny/library/ 1936 1.5 wrecker,1937 gmc coe,1939 Chevrolet coe,1942 4x4 coe, 1942 coe,1946 dump,1947 2 ton dump,another 1947 2 ton dump,1950 coe,1967 c30,1937 cat 22,1936 Chevrolet 5 window foremans coupe, 1914 ford speedster.
| | | | | Joined: Jan 2005 Posts: 75 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 75 | I have a new damper re-done with a double pulley that I want to install. | | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | I have a drill/tap guide setup for threading the crankshaft that's available for loan if you're interested. The crankshaft center bolt size is 7/16-20, same as a small block V-8. Drop me a pm if you're interested in the tooling. I believe the puller holes in the damper are 3/8-16, but I'll be glad to confirm that in the morning when there's some light in the storage shed. Jerry
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | | | |
