2 members (Jay R, Donf), 71 guests, and 3 robots.
Topics128,026
Posts1,055,405
Members48,422
There is a grounding strap from my steering column that is not hooked to anything. I know...hook it to something. Looks like it was hooked to valve cover (only thing it will reach)
My question is what is it grounding??
1966 GMC Suburban 305 V6
Jon S
Las Vegas NV
1966 GMC Suburban 305V6
Psalm 66 "Make a joyful noise"
http://i12.photobucket.com/albums/a205/gvdobler/0205011645b.jpg
Horn, won't make it to firewall to ground, I'm not in favor of the valve cover.
Larry
I don't own a vehicle that isn't old enough to drink.
There's nothing wrong with grounding to the valve cover, as long as your engine is well-ground to the frame.
My 46 GMC on Photobucket
The steering column, is grounded through the rag joint, to the steering gear box, to the frame. There is a ground strap, in the factory rag joint, that jumps through the rubber, from the steering column flange, to the flange that connects to the gear box splined shaft.
Additionally, there are ground straps, in the following areas:
Firewall-to-valve cover - left side
Firewall-to-valve cover - right side
Inner fender-to-frame - right side
Firewall brace-to-frame- right side
