2 members (baldeagle, Oswald), 44 guests, and 10 robots.
Topics128,012
Posts1,055,316
Members48,419
#896814 11/14/2012 10:01 PM
was there any factory 60 Chevy 3/4 4x4 SB built. i ccan't seem to find any info.
thanks
1952 Chevy Suburban
1964 Chevy Suburban
1965 Chevy Suburban 4X4
1941 Chevy Truck
1948 Sedan Delivery
2000 K2500 Suburban
2008 K1500 Suburban
Run with the dogs or [censored] with the puppies
As I recall, all K10 were short box, all K20 were long box in '60.
BC
1960 C60 pasture art
some part swapping going on or frame shortened
Sounds like an axle swap was done, what kind of axles are they?, you should be able to find a date of manufacture on the axle tube to the right of housing. I believe Dodge was the only one with factory 4x4 3/4 shortbeds then.
Perro #897081 11/16/2012 11:56 AM
thanks
how about the ser #. it will tell us what it is and does the ser # on the frame correspond .that should answer your question instead of letting everyone theorize what it may be.
ron
http://www.6066gmcguy.org/VinNumber.htm
he did that ron on the 67-72 website and it was said that it checked out like he said
k10 Offline
1960 was the first year of the corporate 4x4. Longbeds only. 1961 was the first year of the 4x4 shortbed.
k10 #897446 11/17/2012 9:27 PM
your wrong they made shortbeds in 60
k10 #897457 11/17/2012 10:34 PM
You have it backwards. The longbed 1/2 ton 4x4 didn't come out until '61. Shortbed 4x4s and the longbed 3/4 ton 4x4s were both available in '60, as well as having been available from '57-'59, along with a 1 ton 133" wheebase mode from '57-'59. GMC had similar offerings, plus a 114, 123.25, and 133 inch wheelbase 1 tons.
I have found no listing for a factory built '60 Chevrolet 3/4 ton 4x4 though. I would suspect possible parts swapping. Does the truck in question have open knuckles on the front axle? That's a dead givaway that the axles have been swapped, along with possibly having a rear diff without a drop out 3rd member.
Bill Burmeister
Perro #897467 11/17/2012 11:49 PM
you both have wrong info, or knowledge on these trucks,
My information came from several reliable sources. Since you claim that they are wrong, please provide documented proof of this.
Bill Burmeister
I find this amusing. have asked on both boards for the ser # to no avail. if they are forthcoming it will solve the discussion
ron
I'm amused by it, too. I'm curious about the serial numbers, and wouldn't mind seeing some pictures of the truck in question, epsecially the front axle. If it's not a closed knuckle Spicer 44, it's been swapped out.
Bill Burmeister
they made longbeds in 60 in halftons, my info says there were no 3/4 ton shortbeds
Yes, there were longbed 1/2 tons in '60, but not as a 4x4. The 4x4 longbed 1/2 ton came out in '61 in both Chevrolet and GMC. I've checked 3 different sources (one GMC specific), all match on this. All of them also show no short 3/4 ton, which matches your info as well.
Bill Burmeister
oh yes there were
k10 #897635 11/18/2012 5:42 PM
[quote=k10]1960 was the first year of the corporate 4x4. Longbeds only. 1961 was the first year of the 4x4 shortbed. [/quote[IMG]http://i615.photobucket.com/albums/tt238/joek3167/803[IMG]http://i615.photobucket.com/albums/tt238/joek3167/01-25-08_1438.jpg[/IMG]7337285_49fdeaef0e_b-Copy.jpg[/IMG]]
next 1 coming soon on the 60 1/2 ton 4by long bed
According to the 1960 Truck Data Book, the following 4-Wheel Drive Models were available:
K1404 = 4x4, 1/2 ton, 115" wheel base, Stepside Pickup
K2504 = 4x4, 3/4 ton, 127" wheel base, Stepside Pickup
K1434 = 4x4, 1/2 ton, 115" wheel base, Fleetside Pickup
K2534 = 4x4, 3/4 ton, 127" wheel base, Fleetside Pickup
K1405 = 4x4, 1/2 ton, 115" wheel base, 7 1/2-Ft. Panel Body
K1406 = 4x4, 1/2 ton, 115" wheel base, 8-Passenger Carryall (barn doors)
K1416 = 4x4, 1/2 ton, 115" wheel base, 8-Passenger Carryall (clamshell gates)
K1403 = 4x4, 1/2 ton, 115" wheel base, Chassis-Cabs
K2503 = 4x4, 3/4 ton, 127" wheel base, Chassis-Cabs
Bill Burmeister
Neither source indicates a short wheel base (115"), 4x4, 3/4 ton truck, Panel or Suburban Carryall, nor a long wheel base (127"), 4x4, 1/2 ton truck, Panel or Suburban.
I believe a factory-built '60 Chevy 4x4, 1/2 ton, long wheel base (127") truck exists, even though I am not able to find any manufacturer or dealer literature, indicating or supporting this notion.
I took a look at the truck in question over on the 67-72 site (I'm not a member there, though). Something is definitly not right about that truck. The bed is much shorter than the standard 6 1/2' shortbed, and the wheelbase looks to be about the same as a Blazer rather than a short 1/2 ton. Unfortunatly, there aren't any pix of the suspension, axles, and frame, hard to tell what's been altered. But, from what I see, looks like it might have been a long 3/4 ton 4x4 originally, and somwhere along the line it was cut down for an unknown reason.
Bill Burmeister
Your links are bad, no pix.
Bill Burmeister
Perro #897730 11/18/2012 10:30 PM
Perro #897733 11/18/2012 10:34 PM
Authorized Pest
Authorized Pest
I tried to see if I could fix the picture links but the normal "issue" wasn't the problem.
Here is the whole Photobucket album and there is a sub-album for a 1960 Chevy K-20. Perhaps you all can figure what pictures you are looking for.
Hope this helps.
Peg
~ Peggy M
1949 Chevrolet 3804
Hope this helps.
Peg
his last 2 links worked just fine
ron
Perro #898928 11/24/2012 11:59 AM
Hi all to my dissapointment, the good it is a factory 3/4 4x4, the bad, frame was cut down. So i don't have the super rare i had hoped for.
1952 Chevy Suburban
1964 Chevy Suburban
1941 Chevy Truck
1948 Sedan Delivery
2000 K2500 Suburban
2008 K1500 Suburban
so what is yor plans for it?
Perro #899383 11/26/2012 10:53 AM
In this case, it would be "super rare", since there wasn't a short wheel base, 3/4 ton, 4x4 in '60-'66. Good luck with your project. Any photos of the frame mods?
