1 members (UtahYork),
215
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2006 Posts: 98 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 98 | was there any factory 60 Chevy 3/4 4x4 SB built. i ccan't seem to find any info. thanks
1952 Chevy Suburban 1964 Chevy Suburban 1965 Chevy Suburban 4X4 1941 Chevy Truck 1948 Sedan Delivery 2000 K2500 Suburban 2008 K1500 Suburban
Run with the dogs or [censored] with the puppies
| | | | | Joined: Sep 2011 Posts: 1,456 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,456 | As I recall, all K10 were short box, all K20 were long box in '60.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | some part swapping going on or frame shortened | | | | | Joined: Mar 2012 Posts: 211 'Bolter | | 'Bolter Joined: Mar 2012 Posts: 211 | Sounds like an axle swap was done, what kind of axles are they?, you should be able to find a date of manufacture on the axle tube to the right of housing. I believe Dodge was the only one with factory 4x4 3/4 shortbeds then. | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | was there any factory 60 Chevy 3/4 4x4 SB built. i ccan't seem to find any info. thanks how about the ser #. it will tell us what it is and does the ser # on the frame correspond .that should answer your question instead of letting everyone theorize what it may be. ron http://www.6066gmcguy.org/VinNumber.htm
| | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | he did that ron on the 67-72 website and it was said that it checked out like he said | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | 1960 was the first year of the corporate 4x4. Longbeds only. 1961 was the first year of the 4x4 shortbed. | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | 1960 was the first year of the corporate 4x4. Longbeds only. 1961 was the first year of the 4x4 shortbed. your wrong they made shortbeds in 60 | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | 1960 was the first year of the corporate 4x4. Longbeds only. 1961 was the first year of the 4x4 shortbed. You have it backwards. The longbed 1/2 ton 4x4 didn't come out until '61. Shortbed 4x4s and the longbed 3/4 ton 4x4s were both available in '60, as well as having been available from '57-'59, along with a 1 ton 133" wheebase mode from '57-'59. GMC had similar offerings, plus a 114, 123.25, and 133 inch wheelbase 1 tons. I have found no listing for a factory built '60 Chevrolet 3/4 ton 4x4 though. I would suspect possible parts swapping. Does the truck in question have open knuckles on the front axle? That's a dead givaway that the axles have been swapped, along with possibly having a rear diff without a drop out 3rd member.
Bill Burmeister | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | you both have wrong info, or knowledge on these trucks, | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | you both have wrong info, or knowledge on these trucks, My information came from several reliable sources. Since you claim that they are wrong, please provide documented proof of this.
Bill Burmeister | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | I find this amusing. have asked on both boards for the ser # to no avail. if they are forthcoming it will solve the discussion ron | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I'm amused by it, too. I'm curious about the serial numbers, and wouldn't mind seeing some pictures of the truck in question, epsecially the front axle. If it's not a closed knuckle Spicer 44, it's been swapped out.
Bill Burmeister | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | 1960 was the first year of the corporate 4x4. Longbeds only. 1961 was the first year of the 4x4 shortbed. You have it backwards. The longbed 1/2 ton 4x4 didn't come out until '61. Shortbed 4x4s and the longbed 3/4 ton 4x4s were both available in '60, as well as having been available from '57-'59, along with a 1 ton 133" wheebase mode from '57-'59. GMC had similar offerings, plus a 114, 123.25, and 133 inch wheelbase 1 tons. I have found no listing for a factory built '60 Chevrolet 3/4 ton 4x4 though. I would suspect possible parts swapping. Does the truck in question have open knuckles on the front axle? That's a dead givaway that the axles have been swapped, along with possibly having a rear diff without a drop out 3rd member. they made longbeds in 60 in halftons, my info says there were no 3/4 ton shortbeds | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Yes, there were longbed 1/2 tons in '60, but not as a 4x4. The 4x4 longbed 1/2 ton came out in '61 in both Chevrolet and GMC. I've checked 3 different sources (one GMC specific), all match on this. All of them also show no short 3/4 ton, which matches your info as well.
Bill Burmeister | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | next 1 coming soon on the 60 1/2 ton 4by long bed
| | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | According to the 1960 Truck Data Book, the following 4-Wheel Drive Models were available:
K1404 = 4x4, 1/2 ton, 115" wheel base, Stepside Pickup K2504 = 4x4, 3/4 ton, 127" wheel base, Stepside Pickup
K1434 = 4x4, 1/2 ton, 115" wheel base, Fleetside Pickup K2534 = 4x4, 3/4 ton, 127" wheel base, Fleetside Pickup
K1405 = 4x4, 1/2 ton, 115" wheel base, 7 1/2-Ft. Panel Body
K1406 = 4x4, 1/2 ton, 115" wheel base, 8-Passenger Carryall (barn doors) K1416 = 4x4, 1/2 ton, 115" wheel base, 8-Passenger Carryall (clamshell gates)
K1403 = 4x4, 1/2 ton, 115" wheel base, Chassis-Cabs K2503 = 4x4, 3/4 ton, 127" wheel base, Chassis-Cabs
Bill Burmeister | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | Neither source indicates a short wheel base (115"), 4x4, 3/4 ton truck, Panel or Suburban Carryall, nor a long wheel base (127"), 4x4, 1/2 ton truck, Panel or Suburban.
I believe a factory-built '60 Chevy 4x4, 1/2 ton, long wheel base (127") truck exists, even though I am not able to find any manufacturer or dealer literature, indicating or supporting this notion.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I took a look at the truck in question over on the 67-72 site (I'm not a member there, though). Something is definitly not right about that truck. The bed is much shorter than the standard 6 1/2' shortbed, and the wheelbase looks to be about the same as a Blazer rather than a short 1/2 ton. Unfortunatly, there aren't any pix of the suspension, axles, and frame, hard to tell what's been altered. But, from what I see, looks like it might have been a long 3/4 ton 4x4 originally, and somwhere along the line it was cut down for an unknown reason.
Bill Burmeister | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Your links are bad, no pix.
Bill Burmeister | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | | | | | | Joined: Apr 2004 Posts: 5,074 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,074 | I tried to see if I could fix the picture links but the normal "issue" wasn't the problem. Here is the whole Photobucket album and there is a sub-album for a 1960 Chevy K-20. Perhaps you all can figure what pictures you are looking for. Hope this helps. Peg
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | I tried to see if I could fix the picture links but the normal "issue" wasn't the problem. Here is the whole Photobucket album and there is a sub-album for a 1960 Chevy K-20. Perhaps you all can figure what pictures you are looking for. Hope this helps. Peg his last 2 links worked just fine ron | | | | | Joined: Jan 2006 Posts: 98 'Bolter | | 'Bolter Joined: Jan 2006 Posts: 98 | Hi all to my dissapointment, the good it is a factory 3/4 4x4, the bad, frame was cut down. So i don't have the super rare i had hoped for.
| | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | so what is yor plans for it? | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | In this case, it would be "super rare", since there wasn't a short wheel base, 3/4 ton, 4x4 in '60-'66. Good luck with your project. Any photos of the frame mods?
