2 members (55shaker, 1 invisible),
55
Mod | | | Forums66 Topics128,076 Posts1,055,920 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 24 New Guy | | New Guy Joined: Jan 2011 Posts: 24 | I drive my 54 maybe 1,000 miles a year. A couple years a go the heater stopped getting warm. Now it is getting cold in PA and would like to drive it more. Any ideas on what I need to fix to get heat? Thanks | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Does the temp gauge show that the engine is heating up? If not the the thermostat may be stuck open.
If the engine is getting warm (180) or so degrees then perhaps the heater core is stopped up not allowing the hot coolant to flow through it.
Does it have enough coolant in the radiator? If it is low it won't circulate to the heater very well.
My bet is a stopped up or plugged heater core. | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | I assume you do not have a shutoff valve in your hose going to the heater that might be in the off position? Just sayin....
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: Feb 2004 Posts: 29,777 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,777 | After being sure all the valves are open, try reverse-flushing the heater core. Adapt a garden hose to the heater system, and run water backwards to its usual flow. The return line for the heater core generally gets attached at or near the water pump, so make that hose the "input" line during flushing. Let the other line run free- - - -don't flush the crud back into the cooling system. Also be sure you install a 180 degree thermostat- - - -a 160 won't get the coolant hot enough to provide much heat to the cab. Jerry
| | | | | Joined: Jan 2011 Posts: 24 New Guy | | New Guy Joined: Jan 2011 Posts: 24 | Thanks Guys, The 2 hoses coming off the heater control valve are hot. The one coming fron the heater core to the thermostat housing is cool. Does that mean my heater core is clogged? | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Yes... if there are no valves in the hoses, that's a good sign a little bit of heat is getting in, but is severely restricted by a clog so that by the time what little gets through it's cold. | | | | | Joined: Jan 2011 Posts: 24 New Guy | | New Guy Joined: Jan 2011 Posts: 24 | Thanks Roy, Can I back flush the core or do I have to have it professionally redone? | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Gunner - you can give it a flush yourself, but be ready for the leak inside that may well happen afterwards  always a good idea to take the core to a shop and have it cleaned because they'll pressure test it and catch the leaks before they happen Bill | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | As red58 said, you can back flush it. Just be ready. Sometimes they will leak. But certainly worth trying. If it does leak, take it out and have a radiator shop fix it.
If you get lucky and it doesn't leak, you'll have heat.
I wouldn't turn full hydrant pressure on it though, a little at a time to get things flowing. Then you can allow more to go through.
But if you hit it with full hydrant pressure, you may be assured of a leak. Those old cores only had around 7lbs of pressure on them. | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | if you have no flow,the hoses to the heater control valve won't be hot, the water has to be moving through the hoses to make them hot. With the exception of a little conduction. according to the factory installation instructions no hose should go from the thermostat housing to the heater core, it goes from the pump to the heater, out of the core to the control valve, then to the thermostat housing. look on the old online chevy manuals, it is in accesories or something. It isn't acutally in the shop manual. make sure you have it plumbed correctly.
| | | | | Joined: Apr 2005 Posts: 1,107 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,107 | where in eastern pa are you located? | | |
