7 members (Bill Hanlon, 52Carl, ShopRag, Wickedbass, Hotrod Lincoln, 59 fleet, Otto Skorzeny),
53
Mod | | | Forums66 Topics128,009 Posts1,055,291 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | on my 1958 powerglide the tranny shifts a little too late i think , it shifts around 35 mph, by my speedo , is that normal ??? it down shifts just fine , i have checked the fluid ,its fine, somone fill me in please
thanks
1958 chevy biscayne 235 6 cyl 1 barrel 2 speed PG tranny
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Do you have 2-speed Powerglide, which I do not see listed in the 1958 truck specification manual (but was available in later years), or do you have the 6-speed Powermatic that was available in 1958 trucks?
What color ID plate (and ID code) is on the transmission?
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Accarding to the '59/60 Suppliment, the upshift points w/235 and 3.36 axle are; Throttle Closed 12-15 mph, Detent Touch 27-44 mph, Through Detent 44-49 mph.
Bill Burmeister | | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | Sorry i dont undersand all that
| | | | | Joined: Sep 2011 Posts: 1,451 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,451 | At engine idle it will up shift from 12-15 mph moderat throttle opening will upshift from 27-44 mph At WOT (full throttle) it will upshift from 44-49 mph That is all with stock 3.38 axle ration & tires that are the same rolling circunfrence as stock.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | Ohh ok i see now thanks, , moderat throttle 27-44 seems high 44,wow maybe mine is right on then, ,is there a way to chang it?
| | | | | Joined: Feb 2004 Posts: 29,742 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,742 | Change the length of the throttle linkage from the carburetor to the transmission. I don't recall which way to move it, but lengthening the linkage will move the shift point up or down, and shortening it will have the opposite effect. DO NOT GO FOR AN EXTREMELY SOFT SHIFT! It will cause the clutches to slip and burn. A powerglide has two shift speeds- - - -too low and too high! Jerry
| | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Because a powerglide is essentially missing first gear compared to a 3-speed, don't concern yourself with it shifting too high. As long as it shifts well and isn't over-revving the motor it's not a big deal. | | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | thats what i am affraid of ,, seems to me it should shift sooner ,, but could be me , i drove it all weekend and seems like i could play with gas and make it shift sommer , by revving it and when i want it to shift just let off a tiny bit , or anyway seems like ,,,
thanks
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | I always thought the PG basically missed 2nd gear. That's why the waited a bit later to shift.
Either way, they do delay shifting a bit longer than most automatics. | | | | | Joined: Sep 2011 Posts: 1,451 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,451 | Sounds as if it could be operating as designed. It's a big jump from lo to direct, if it shifts upshifts any sooner it will have to downshift again with just a slight load or throttle increase. Every Power glide I've ever driven sounded like a s screaming jet right before WOT upshift.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Jul 2012 Posts: 306 Shop Shark | | Shop Shark Joined: Jul 2012 Posts: 306 | Thanks good to hear,, i was hoping it wasnt bad,
