| | | Forums66 Topics128,102 Posts1,056,184 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | Did any of the 30s/40s GMC trucks use the 208 CID Pontiac flathead 6 or were they all Chevy style overhead 6s? I know that Pontiac engines were used at one time in the GMCs. Any GMC historians out there.
Weeds | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | I believe GMC used Chevrolet (207 in 1935), Oldmobile (230 in 1937) and Pontiac engines (223 in 1938), then they started using their own 228. I tried looking up wiki, but couldn't find the information you needed. | | | | | Joined: Nov 2000 Posts: 1,969 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,969 |
Professional Novice
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | GMC used mostly Pontiac and Oldsmobile flathead 6 cylinders through the '30s, seems Pontiac engines were used up to '33, Olds engines '34 and later, though there was some models that used Pontiac engines later than '33. This excludes certain models (mostly 1.5 and larger) that used Buick engines. In '39, GMC used their own engines in lighter trucks, heavy trucks still used the Buick based 6 cylinder.
Bill Burmeister | | |
