1 members (TooMany2count),
120
Mod | | | Forums66 Topics128,193 Posts1,057,257 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2012 Posts: 40 New Guy | | New Guy Joined: Aug 2012 Posts: 40 | here's the scoop.... My project 46' half ton has no title. --applying for a builder title and inspections (several) will be a huge pain in the [censored]
I have a chance to buy another truck... 46 1.5 ton with a clean title...
My thought was to use that title for my 1/2 ton project? maybe apply for a builder title and re tag it as a 1/2 ton later....
Ideas, thoughts?
After searching for a year I found the next project! 46' 1/2 ton in pieces! took 2 trips to get it home, but most of the hard work was already done!!! -jerry "Phil" the 46' | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Not a good idea, as it is illegal to falsify vehicle ID.
Bill Burmeister | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | I am sure you will get lot's of "Thought" on this subject. It has a real easy answer "IT'S ILEGAL" to take a title from one truck to another, although it is done all to often. | | | | | Joined: Aug 2012 Posts: 40 New Guy | | New Guy Joined: Aug 2012 Posts: 40 | but if I use the cab and doors off the titled truck and maybe a nut and bolt or 2.... I'm happily in that grey area!
The motor is getting swapped as well.... so any reference would be replaced anyway...
I also have an option to file for a VIN number that state patrol will attach to the frame... it's part of the builder title junk.
