| | | Forums66 Topics128,006 Posts1,055,268 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#89686 08/23/2003 3:13 AM | Joined: May 2000 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: May 2000 Posts: 69 | I need help troubleshooting a problem with the charging system. This is a 53 Chevy 1/2 ton with original everything and 6 volts. It was working fine up until today. It had sat for a week. Cranked a little slow, but it usually does after sitting that long. Started, but the ammeter didn't go over into the + side like it usually does for a while until the battery recharges. Six miles to work and needle didn't move off center. At idle it showed a slight discharge as usual, and the directionals were slow blinking. I checked the belt and it's not slipping. CHevcked for obvious broken wires. Tapped the voltage regulator but that didn't budge anything. According to the manual, it could be anything from corrosion to a malfunctioning generator or regulator. Where do I start? I've got a multimeter, but electricity isn't my strong suit and I don't want to fry anything. I'd appreciate some help. | | |
#89687 08/23/2003 6:55 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Check for bad grounds, of course ... also, what size battery cables do you have on there? Make sure they're a good size - like #2 ... which I guess they are; you said this just started up, so I'm thinking something is grounding out.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
#89688 08/23/2003 7:10 AM | Joined: Mar 2001 Posts: 279 Shop Shark | | Shop Shark Joined: Mar 2001 Posts: 279 | Are your battery cables hot? Sounds like a ground to me as well. If you have the common grounding strap for 6 volt, you might disconnect it from where it is grounded to the frame and wire brush it to make sure you are getting a good ground. Mine did that before and the cables got hot as well. Once it was cleaned off, it was fine. I'd check both terminals for corrosion while you're at it. Don't know much about generators as mine has an alternator, but could it be worn brushes? Probably not, but just a thought. Somneone else will know better than me on that. | | |
#89689 08/23/2003 7:54 PM | Joined: Jul 2002 Posts: 91 Member | | Member Joined: Jul 2002 Posts: 91 | It sounds like you are driving on your battery power. I had the same problem last monday. My generator went south and quit. One brush broke of. Check with your multymeter if you have any power comming out from your generator. Engine has to run higher than idle. | | |
#89690 08/25/2003 4:56 PM | Joined: Aug 2002 Posts: 221 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Aug 2002 Posts: 221 | My 46 acted exactly the same. It was working OK then went 'dead'. I took the generator and regulator to a shop and it was the regulator at fault. Had the generator refurbished and bought a new regulator, all for less than $100 US. The system works perfectly now and even carries the headlights at a relatively low speed. Hope this is what you need for the 53! Cheers. George | | |
#89691 08/26/2003 4:26 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Either your generator or regulator has problems. Here's some good advice in a previous post. Generator not generating
Fred 52 3600 69 C-10
