0 members (),
126
Mod | | | Forums66 Topics128,113 Posts1,056,619 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2006 Posts: 92 Shop Shark | | Shop Shark Joined: May 2006 Posts: 92 | I have a 1955 235 with the original 4 speed transmission in my 48 Chevy 1/2 ton. Is it possible to bolt a turbo 350 up to the 235? Or should I put in a sbc? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Buffalo Enterpises makes an adapter palte to bolt a leter automatic to the 235. While the TH350 will work fine, you might consider the TH700R4, which has a better first gear ratio as well as an overdrive gear. You will need to go to an open driveshaft, the easy way would be to swap the 3rd member/torque tube of your existing rearend out for a 3rd memebr from a '55-'62 1/2 ton truck and weld up the pivots. That will allow you to keep the proper width rear and yur 6 lug wheels.
Bill Burmeister | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I agree with LONGBOX55, don't use a turbo 350. At 60 mph, you will be turning high RPM's. A TH700R4 will give you an overdrive gear and you should be able to run 70 mph at about 2400 RPM's with a rear end gear ratio of 3.55. For a 235, that is very comfortable. With the Buffalo Enterprises adapter, it makes a nice finished product.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: May 2006 Posts: 92 Shop Shark | | Shop Shark Joined: May 2006 Posts: 92 | Whats the approximate cost for the adapter? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | You won't get better answers by having 2 threads about this. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | I would think you need to call Buffalo Enterprises and ask them.
BUFFALO ENTERPRISES
25625 Dahl Road, Arlington, WA, 98223 (360) 652-7684
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I used the Buffalo adapter to put a 2004r in my '54 GMC. | | |
