4 members (Jon G, 5 Window 9434, Charles in CA, dt235sd), 54 guests, and 0 robots.
Topics128,049
Posts1,055,635
#896455 11/13/2012 1:32 PM
I'm just getting all the parts together on my 48 3100. It has a 56 model 235 in it. After I put the radiator in I noticed that the fan sits way low on the radiator. Does everyone have this same situation with a 235 in a 47-54 Chevy truck?
57210 #896457 11/13/2012 1:39 PM
One of the members of this site makes a conversion plate that allows the early-style water pump to be installed on the late engine. The 216-style water pump fits the higher location and puts the fan back into the right position. Two holes need to be drilled and tapped, but it's a relatively simple conversion.
57210 #896466 11/13/2012 2:50 PM
The person that has the water pump conversion is Pre68Dave,I used one on my 52 with 235 engine and it works great and is easy to install.
Pete
Do a search on Pre68Dave and PM him.
57210 #896467 11/13/2012 2:52 PM
Yes, pre 68 dave. As many, I too used the adapter plant/conversion with no issues.
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
