0 members (),
97
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#89600 02/18/2005 12:04 AM | Joined: Sep 2004 Posts: 93 Member | | Member Joined: Sep 2004 Posts: 93 | Hi all, I'm installing an electric fan and have a question. It was my understanding that the fan should be mounted as low as possible for maximum cooling effect. I will have to mount mine high, above the water pump, because the water pump shaft hits the electric fan. Will this be okay for cooling? Note, this is not a stock engine.
Thanks, Don | | |
#89602 02/18/2005 9:48 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Heat RISES, bro' ... the HIGHER you mount the fan, the more cooling you're gonna get. The reason I put an electric fan in my truck was that my mechanical fan was sitting too low and not performing well enough. [img] http://www.alanhorvath.com/54chevy/chevypics/rad_back_newold.jpg[/img] If you're using a 16-inch fan, I suggest you use Two Relays -- See Here I also believe in using a Fusible Link instead of a circuit breaker (and definitely NOT a fuse).
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
#89603 02/18/2005 12:14 PM | Joined: Sep 2004 Posts: 93 Member | | Member Joined: Sep 2004 Posts: 93 | Thanks Joe and Alan for your comments. After I posted my question I got to thinking about it and figured I had it wrong in my mind. The hottest part of the radiator would be the top and that's where the fan should be mounted. Alan, I have been to your website many times and read all about your electric fan installation and the need for relays. I tried for 8 hours (yes, 8 hours)yesterday to call Mark at M.A.D. Electrical. I finally got through at 5:45 PM PST and talked to him about my needs. I ordered 2 relay kits for the fan and at the same time the alternator kit. Mark is very helpful and a nice person to talk to, but he sure is hard to get a hold of. Thanks again, Don | | |
#89604 02/18/2005 12:27 PM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Hey, Don
I'm glad you finally got to talk to Mark -- he's hard to get hold of, but it sure is worth it when you do, eh?
That alternator kit is great -- be sure to put the diode on the ignition wire -- what a difference THAT made for me!!
#89605 02/18/2005 10:53 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Are you running an AD? Mount it on the street side of the radiator in a pusher configuration. It's more efficient that way, and you can't see it. It fits pretty well on that side.
#89607 02/19/2005 10:46 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | I agree with TooMany2Count ... I've always heard that a puller is much more effective.
#89608 02/19/2005 1:25 PM | Joined: Sep 2004 Posts: 93 Member | | Member Joined: Sep 2004 Posts: 93 | I installed my electric fan yesterday in a "puller" configuration. As soon as I get my relays from MAD I'll wire it up. I would like to install a switch so that the fan can be turned off for highway speeds. I've always heard that an electric fan is more of a hindrance than a help when you're traveling fast enough to get good air flow through the radiator. Any comments? Thanks, Don | | |
#89610 02/20/2005 1:07 AM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | painless wiring has a switch that attaches by a bolt on the side of the radiator that is temperture sensitive which would automaticly turn the fan on and off as needed. works like the new cars. no drilling needed to install attaches to an the radiator mounting bolt. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
