7 members (Otto Skorzeny, 1955 1 Series, Rusty Rod, baldeagle, dt235sd, Woogeroo, Hotrod Lincoln),
369
Mod | | | Forums66 Topics128,165 Posts1,057,087 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2012 Posts: 74 Shop Shark | | Shop Shark Joined: Sep 2012 Posts: 74 | Does anyone know where to get rear brake shoes for our 49 3600?
We checked LMC and American Classic. Neither list them on their websites. Our shoe material delaminated and needs to be replaced.
Better yet, does anyone know where we can find riveted shoes rather than glued??
Thanks! J&K | | | | | Joined: Mar 2004 Posts: 874 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 874 | Check bowtiebits.com. They probably won't have riveted linings though. Another option is to find a local truck repair shop and have them reline your shoes. | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | Local auto parts stores should have access. Like this one
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Sep 2012 Posts: 74 Shop Shark | | Shop Shark Joined: Sep 2012 Posts: 74 | Bowtiebits.com works for me. Heavy core charge though, $150!! Maybe its a typo.
Thanks for the advice! | | | | | Joined: Nov 2000 Posts: 1,972 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,972 | It's probably not a typo... Those huck-type brake parts are getting scarce.
Professional Novice
| | | | | Joined: Aug 2011 Posts: 687 Shop Shark | | Shop Shark Joined: Aug 2011 Posts: 687 | Why not just have yours relined? That's what I did. I also have a spare set just in case.
PS, drums are harder to find, so careful when turning... | | | | | Joined: Sep 2012 Posts: 74 Shop Shark | | Shop Shark Joined: Sep 2012 Posts: 74 | Why not just have yours relined? That's what I did. I also have a spare set just in case.
PS, drums are harder to find, so careful when turning... How much was the relining? Where should we look? | | | | | Joined: Mar 2007 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 65 | Try Jim Carter Truck Parts at 1-800-336-1913 or this link http://www.oldchevytrucks.com/cart/product.asp?prodid=ME1431&i=|brake|||49|
Their website is not the easiest to use, but lots of parts and you can always call them for more info. I bought Huck brake shoes for my 1949 GMC 3/4 ton through Jim Carter. | | |
