3 members (2-Ton, Mike B, 1 invisible), 69 guests, and 2 robots.
Topics128,030
Posts1,055,419
Members48,422
#895887 11/11/2012 1:10 AM
hello everyone I have a 1951 chevy 3100 (pick-up)with a 216 and i am removing the oil pan and i have heard that you have to lift the eng at the front and i have also heard that it will come down with ease and i have also heard to take the plate by the flywheel off and it should come down. well i thought i would try and i have removed all the hardwear and the oil pan doesn't want to come down from the front, the back come down a good amount. so my question to you is what should i do to remove the oil pan what is the best way?
misfits #895931 11/11/2012 9:03 AM
You should not need to remove or raise the engine to remove the oil pan on your 216. If you are sure you have removed all the bolts(run your finger around the pan rim to make sure) maybe tapping on the pan to pop it lose would help. Than just lower the back and slide the pan rearward for clearance.
Drew
misfits #895935 11/11/2012 9:17 AM
dont know about the 216 truck but on my 235 biscayne there is no way the pan would come off unless the motor was pulled dont care what anyone said ,,
1958 chevy biscayne
235 6 cyl 1 barrel
2 speed PG tranny
lilrobo #895950 11/11/2012 10:15 AM
Riding in the Passing Lane
There is a big difference in the biscayne & a truck. The truck has a straight front axle & does not have a crossmember under the engine.
1972 Chevy c10 Cheyenne Super
misfits #895987 11/11/2012 12:55 PM
If the pan is loose, it may be getting humg up on the front motor mount oil shield. I got rid of mine because of that.
1951 1 Ton Completed
misfits #895993 11/11/2012 1:51 PM
yea it's hitting on the motor mount oil shield. Did you just cut it off?
misfits #895995 11/11/2012 1:55 PM
Sometimes just turning the engine a little gets the front crank counter balance weight out of the way making it come off easier.
My Blog
misfits #896018 11/11/2012 3:52 PM
got it out had to remove the flywheel covers and down it came. thnx for the help
misfits #896048 11/11/2012 6:26 PM
Ex Hall Monitor
Ex Hall Monitor
On my '38 216 I have to either pull one end of the tie rod or one end of the cross member aft of the pan then swing it out of the way.
