| | | Forums66 Topics128,021 Posts1,055,346 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#89582 02/13/2004 1:05 AM | Joined: Feb 2002 Posts: 75 Member | | Member Joined: Feb 2002 Posts: 75 | another stupid 12v conversion question: Is my 6v ammeter going to be ok with 12v single wire alternator conversion? I assume the single wire goes directly to ammeter, then to bat.
this seems correct, but just checkin'
thanks.
'53 chevy 3/4 ton
#89583 02/13/2004 3:40 AM | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | No such thing as a dump question. Your actually very wise to ask before hand.
All of the high amperage Alternator conversions I've been installing come with an extra by-pass wire to divert some of the alternator current directly back to the battery and not through the ammeter. I would also be wise to purchase (2) fusable links "two wire size small then the wire your protecting" to install on the BAT terminal on the alternator and the other end crimped onto the wires going to the ammeter and the battery. If their is a problem the fusiable link melts and not the entire wire which will save you a lot of wiring repair time.
Joe
Joe
#89584 02/13/2004 6:21 PM | Joined: Aug 2003 Posts: 264 Member | | Member Joined: Aug 2003 Posts: 264 | Your stock ammeter should be just fine. Current is current. All an ammeter does is measure the current to or from the battery. | | |
#89585 02/16/2004 6:13 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I'm running a Delco 10si (63 amp) alternator in my truck through the stock ammeter and it works great. It has never even deflected all the way, even with a low battery. If you go to anything bigger than a 85 amp alternator you may want to do something with the gauge though.
