| | | Forums66 Topics128,154 Posts1,056,842 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | After about 350 miles I now notice the doors popping as they rub against the vertical cowl. 350 miles and no problem. Is the fix for this (adjustment of the hinges) the only solution or does anyone have a shortcut of warning of what not to do.
~Jim
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Sounds like you need to adjust the door back. How are the hinges? Those trucks have a bad habit of the hinge pin rusting and locking in the area where they should pivot. When this happens the pin starts pivoting in the mount which has very little surface area. This will wear fast causing the door to sag.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I forgot to come hack here and explain what I found. Looking at the clearance on the door to cowl it was obvious it wasn't the problem. I happened to look at the leading edge of the door and saw a round 1/4" diameter scratch. I then realized it was caused by the door popper (interior light switch). The problem was solved with a dab of grease on the scratch. The mystery is, why would the scratch-pop sound come from both doors at the same time. Must be the weather.
~Jim
