5 members (tclederman, FAST55, Joe H, lumbersawyer, 1 invisible), 69 guests, and 2 robots.
Topics128,023
Posts1,055,367
Members48,420
#89557 05/12/2003 2:36 AM
i know its off the subject, but i fried the fusable link (so im told) in my 1977 daily driver. i went out and bought a new one, but cant find the old one! where is it? can anyone help
GOING FAST IN A CHEVY, IS THE ONLY WAY TO GO
#89558 05/12/2003 2:50 AM
Try up on the fire wall there is a black peice of plastic to the left of the brake booster with several wires attached to it. The fuseable link is a red colored wire that has a barrel shape about 3 inches or so from the end.
hope that helps. Ray
#89559 05/23/2003 4:49 AM
Y
Y Offline
Check by the starter running off of the positive battery cable. Also make sure none of the wires are melted on the exhaust manifold.
1954 Chevy 3100 235
2 Yamaha YSR50's
05 Silverado crew
00 Yamaha TT-R125 Supermoto
#89560 05/28/2003 11:38 AM
Question is which fusible link? There could be more than one ... but a "fusible link" is nothing more than a wire one size smaller than the one it's connected to - intended to melt/burn a disconnect and save things from getting worse.
I'd look for a "broken wire" and add the new fusible link to that ... nearby should be the connection it needs to go to.
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#89561 05/28/2003 5:17 PM
normally they attach directly to the positive wire at the starter or sometimes at the battery, diconnnect the neg lead and gently pull on the wires, they normally have a rubbery type insulation and maybe a flag on them as well as
well.
