0 members (),
66
Mod | | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#89557 05/12/2003 2:36 AM | Joined: Sep 2002 Posts: 3 Member | | Member Joined: Sep 2002 Posts: 3 | i know its off the subject, but i fried the fusable link (so im told) in my 1977 daily driver. i went out and bought a new one, but cant find the old one! where is it? can anyone help
GOING FAST IN A CHEVY, IS THE ONLY WAY TO GO
#89558 05/12/2003 2:50 AM | Joined: Feb 2001 Posts: 80 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2001 Posts: 80 | Try up on the fire wall there is a black peice of plastic to the left of the brake booster with several wires attached to it. The fuseable link is a red colored wire that has a barrel shape about 3 inches or so from the end. hope that helps. Ray | | |
#89559 05/23/2003 4:49 AM | Joined: May 2003 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: May 2003 Posts: 27 | Check by the starter running off of the positive battery cable. Also make sure none of the wires are melted on the exhaust manifold.
1954 Chevy 3100 235 2 Yamaha YSR50's 05 Silverado crew 00 Yamaha TT-R125 Supermoto
#89560 05/28/2003 11:38 AM | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Question is which fusible link? There could be more than one ... but a "fusible link" is nothing more than a wire one size smaller than the one it's connected to - intended to melt/burn a disconnect and save things from getting worse.
I'd look for a "broken wire" and add the new fusible link to that ... nearby should be the connection it needs to go to.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | |
#89561 05/28/2003 5:17 PM | Joined: Jan 2001 Posts: 198 Member | | Member Joined: Jan 2001 Posts: 198 | normally they attach directly to the positive wire at the starter or sometimes at the battery, diconnnect the neg lead and gently pull on the wires, they normally have a rubbery type insulation and maybe a flag on them as well as well. | | |
