6 members (Wooley, Otto Skorzeny, Ponchogl, Southerntruck, Stewart2, Hotrod Lincoln), 210 guests, and 1 robot.
Topics128,102
Posts1,056,532
Members48,448
#89545 08/08/2003 12:42 AM
k10
Offline
http://www.stovebolt.com/gallery/vongunten_gene_1946_01.htm
I wonder if anyone could comment on the last line of this gallery submission. It sounds very interesting, as a way to get a quicker start but maintain originalty.
#89546 08/08/2003 3:32 AM
I have posted about this many times. Get yourself some 2/0 cable for the positive and negative battery terminals. Be sure the grouding side ( in your case the positive ) is bolted to something heavy as close to the starter as possible. Add a heavy ground strap from the frame to the block.. Also be sure all the connections are clean..Do all of the above and your 6 volt starting troubles are history..
An 8 volt battery will mask the inadequacies of your electrical system for a short time, you will have to address them eventually. Big waste of cash in my view..
I run a 6 volt Optima battery in my truck with 2/0 cable, the starter never fails to spin like crazy.
Pay attention to Kook's and MT's comments here.
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=3;t=000676#00 0003
Bill M
53 GMC Hydra-Matic
Home Page
http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
#89547 08/08/2003 9:18 AM
k10
Offline
Baddabing.
#89548 08/08/2003 2:50 PM
When I first got my truck before I knew it was converted I asked the board about switching to 8 volts and was told not too due to the fact that you will wear out your bulbs faster. I agree that make sure your electrical sys is top notch and there is no need!
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
