7 members (Rusty Rod, TUTS 59, Phak1, Napco Man, Cosmo, ndkid275, 1 invisible),
52
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | The heater motor in my '48 is performing off and on right before a cooling down period is predicted. 4 deg on Saturday night.
What am I up against in removing all the stuff to get the motor out? Does it all have to come out, core included, to get at the motor? Do I have to remove it piecemeal?
Thanks! I don't want to start this w/o knowing what's involved, especially if it's cold outside. (Mrs. Wally gets the garage!)
1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | What model heater do you have?
| | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | Here's a picture. Heater.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | You have to remove it from the truck to get the motor out. Removing the front cover only shows you the cage ...pic... ...pic... | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: May 2001 Posts: 1,904 'Bolter | | 'Bolter Joined: May 2001 Posts: 1,904 | 1948 3/4-Ton 5-Window Flatbed Chevrolet 34 Years. Now with a '61 261, 848 head, Rochester Monojet carb, SM420 4-speed, 4.10 rear, dual reservoir MC, Bendix up front, 235/85R16 tires, 12-volt w/alternator, electric wipers and a modern radio in the glove box.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | That's a fresh air heater. Just remove the entire heater and if you are not rushed I would break it down and rebuild it. That way it will give you many more years of service. If you need to replace the motor many vendors carry both 6 and 12 volt motors.
~Jim
| | | | | Joined: Jun 2011 Posts: 63 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 63 | I just bought a brand new (12 volt) motor for my heater at NAPA. Less than 40 dollars. Fits perfectly. Mine is a recirculator type, but I am sure the one you need should be at about the same price range. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Is your heater motor 6v or 12v? If your motor is 6v, some 'Bolters have replaced their 6v motors with 12v motors. You may be able to buy their 6v motor from them. Post an ad. Also, there are some guys who work on old motors that may be able to fix your 6v motor. I'm sure that other forum members can give recommendations. If you motor is 12v, you may find a 12v motor from a '60s GM car ... probably not an easy find, but possible. I have a '60 Impala 12v heater motor in my '54 Fresh Air heater. Your squirrel cage will mount onto the 12v motor with no modification. You will need to file about 1/16" from the mounting holes in the heater case. (12v aftermarket heater motors also require this.) Here is my original 6v motor on the left, the rusty '60 Impala 12v motor before sandblasting in the middle, and an aftermarket 12v motor on the right. > CLICK - beforeHere is the Impala motor cleaned up and mounted. > CLICK - afterEDIT - I just noticed that your signature line states that your truck is 12v. The second part of my post applies. If you still have the original 6v heater motor, please don't toss it, another member may need it. Or, you can hide an (ugly) after market 12v motor inside the 6v case, like DADS50 did.
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Nov 2012 Posts: 4 New Guy | | New Guy Joined: Nov 2012 Posts: 4 | The motor is held in place by the shell of the heater unit which would have to be partly dismantled.
Inside this casing is also the heaters matrix and all the valves and gates for the ducting. To remove the heater as a dash has to come out, Not a job I would fancy. Some crafty/good back street auto mechanic may have a wrinkle or two but don't hold your breath.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | To remove the heater as a dash has to come out, Not a job I would fancy. The dash does not have to come out to remove a fresh air harrison heater on an Advanced Design truck . Simply remove the bolts on the kick panel and the firewall The duct hoses and two core hoses | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | One of the easier jobs on the AD
~Jim
| | | | | Joined: Oct 2010 Posts: 171 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 171 | One of the easier jobs on the AD ...would agree, put the 3 clutch head bolts on the backside of my heater were a bear to get out!
....David
