4 members (Hanks custodian, Otto Skorzeny, cmayna, 1 invisible), 85 guests, and 0 robots.
Topics128,108
Posts1,056,567
Members48,448
For what reasons I am not sure, incorrect name, or whatever, I cannot find discussion or source for kick panel replacement on 52 chevy 1/2 ton. They are rusted through along fender line.
Would consider repair. Any suggestions there appreciated as well.
Thanks, brad
1952 Chevy 1/2-ton
"Me and Ol Blue/True Blue Both Born in '52"
Follow this fun story in the DITY
Awww, the "inner cowl panel". now to replace, repair, or patch?
Brad
1952 Chevy 1/2-ton
Try a search above on "inner cowl" (use the quotations).
It will return these results. Not all the links will be appropriate, but some should cover what you looking for:
inner cowl (different lengths of panels),
outer cowl (different lengths of panels),
inner-to-outer channel, etc.
Post links to photos, and people will be able to better advise you.
This is a commonly needed repair. There are a variety of possible pieces, depending on the extent of your rust.
Brad, that was very helpful, great pics. Thanks, Brad
1952 Chevy 1/2-ton
