0 members (),
79
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 65 | 37 1/2 ton orriginal have just got to a stage where I have backed truck out of the garage for the first time Experienced severe Chatter on starting - have inspected flywheel an noticed area gouged out on the rear edge ( foot starter has been sounding strage at times too) Does the starter motor engage the flywheel fron the front or the rear? Also whats the best way to diagnos/solve the clutch chatter
Thanks Den
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Den99, the starter engages the flywheel from the front side. As far as the "chatter" goes, there may be rust on the flywheel and/or the pressure plate, or both, plus there may be particles of rust embeded in the clutch disc. All of those conditions will cause clutch "issues", and the embeded rust in the disc will most likely not come out on its own, hope that helps. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | How are the motor mounts? Bad mounts can cause clutch chatter.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jul 2010 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2010 Posts: 65 | Thanks for replies Rear motor mount are new (front old) If Starter engages from front - what would cause gouge on rear of flywheel - the teeth are literaly bured off about 1/8th of an inch?
are there any further check i should do before getting transmision taken out | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Someone has probably "flipped" the ring gear at sometime in the past. A ring gear is a shrink fit on the flywheel, and it can be driven off carefully with a mallet and a brass punch, heated to expand the diameter, and reinstalled with the "good" side facing the starter drive teeth. It was a pretty common "shade tree" fix for guys with a little ingeneuity and a tight budget! Jerry
| | | | | Joined: Feb 2011 Posts: 583 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 583 | Just curious. What are you considering as the front or back of the flywheel? I've always thought of the backside of the flywheel being the engine/crankshaft side, and the front being the clutch pressure plate side.
1939 Chevrolet Stake Truck
| | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | When everything else from the radiator to the bumper to the headlights is called "front", why would the flywheel be different? Jerry
| | | | | Joined: Oct 2007 Posts: 91 'Bolter | | 'Bolter Joined: Oct 2007 Posts: 91 | rickmg, I understand your question, some people look at the flywheel from the clutch side and call that the front or face of the flywheel.Den99 the starter engages the flywheel from the starter side of the flywheel
