Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Peggy M, MNSmith), 240 guests, and 4 robots.
Topics128,282
Posts1,058,495
Members48,490
#895237 11/07/2012 9:43 PM
Hey Guys, I did a compression check on my engine last night just for the heck of it and noticed I was getting 80 PSI on all 6 cylinders. I searched the forum and found it should be around 120. Should I rebuild or just keep running it? It runs fine and feels like it has plenty of power. Just hate to spend alot of money on something that works. Just fishing for advise.
If it's broke hit it harder!
I will add the truck is in the process of being restored and hasnt really been driven any major distance in 30 years. I also have had 3 bent push rods since I took over ownership.
With compression that low and even across the board I question how accurate your gauge is.
My Blog
I plug my compression gauge into an air compressor line occasionally to compare its reading to the tank gauge. 80 PSI translates to about a 5.5:1 compression ratio, which is a bit low, but a lot of the time low cranking speed and/or slightly sticky valves can combine to give a somewhat lower than accurate reading.
Its a chepo guage from harbor freight. I'll check it with my compressor. Thanks for the info.
