7 members (Gdads51, Guitplayer, Donf, FAST55, papas52, DougH6100, Hanks custodian),
82
Mod | | | Forums66 Topics128,162 Posts1,056,950 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 127 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 127 | Tried filling the radiator of my non-runner 216 for the first time today and noticed my feet getting wet. Turns out the front freeze plug was missing. Pulled radiator and fan and found the plug on top of the gunk in the radiator support - it is the steel disk kind, mostly flat with slight convexity in center.
Previous threads are helpful, but still a couple Questions: 1. is a blown freeze plug a symptom of anything particular to check, or should I just replace and see what happens? Would you guess it blew running or froze while parked in winter? 2. Is it important to find the same type plug? Napa and the vendors only seem to have the cup type or dome-shaped. Brass or steel? Use the old one? 3. any good tricks for cleaning the rust in the hole and setting the plug? Previous threads say put in freezer before installing, use a socket to hammer it in and seal with permatex 2.
52 3100 project 54 3100 / 3112 ice cream truck, next project
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | It will be the domed type and when installing you tap on the front of the dome so that it spreads out and seals. There will be a ledge inside the hole in the block that it will stop against. I like to use some sealer too. In my case, after the one on the front of the motor failed, the one in the rear did the same thing. They were old and rusting around the edge. | | | | | Joined: Oct 2009 Posts: 127 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 127 |
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The description seems right although I don't know the size off hand. The photo looks a bit odd because it doesn't have sides to it. I think the photo is either generic or there is a shadow from the flash that looks like it has a side to it. Anyways, calling it a disc is how I would describe it. | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | That core plug from Napa looks too thick. I guess it is cheap enough to purchase and find out. Otherwise the usual online vendors sell the plug as part of the plug "kit". Never bothered to look for it individually. | | | | | Joined: Oct 2009 Posts: 127 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 127 | Well I got the NAPa domed steel disc type. It was a good fit, but there is no lip to hold it in. Tapped on the dome, but have no idea if it will hold - doesnt inspire much confidence...
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I guess tapping was a poor description. You have to hit the centre of it so that it spreads the side and forces it out in the bore. One technique is to place a hammer against the plug and hit the hammer with another one. | | | | | Joined: Oct 2009 Posts: 127 'Bolter | | 'Bolter Joined: Oct 2009 Posts: 127 | Thanks. Will try one big whack with a big hammer on a smaller one. Seems like the trick is to hit it hard enough to "dimple" the center and spread the plug, but not so hard to distort it and cause a leak. About how much of a dimple works well - dime size by 1/8"? bigger, smaller?
NAPA only sells bags of 10, so if it fail, at least I have spares, but would rather avoid that!
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | In a perfect world you would have a tool that had the exact contour that would result in a perfect curve. Since that is not the case, I would think that spreading out the force as much as possible would be a good thing. | | |
