4 members (Bill Hanlon, Otto Skorzeny, gswbbc, dt235sd), 83 guests, and 3 robots.
Topics128,047
Posts1,055,532
Members48,424
#89518 05/17/2005 2:00 PM
Junior Member
Junior Member
First off I would like say what a great site. A lot of info and talent is concentrated here. Currently I am restoring a 56 Chevy 1.5 ton truck. 235 6 cyl., 4-speed manual transmission. Great truck. Actually going to shoot color on her this weekend. Anyway, heres my question: While the engine is running, if I remove one of the battery cables off the battery, the engine stops running. What could be causing this. At the battery, when I put my Fluke meter on her while running I get 12.5----12.9 volts. Any suggestions
Thanks, Jason
#89519 05/17/2005 3:10 PM
I thought that I rememer someone tell me that was the test to see if the alt/gen was working,,if it died it meant it was not charging but I am not sure about it,, also thought that a running eng should show 13 or plus volts on the meter,, but what do I know, they call me the Joker and welcome to the bolt,, you will enjoy,,,,,,,,Fred
Redryder pix
My Hotrod
#89520 05/17/2005 4:53 PM
Welcome to the Stovebolt!
Joker is right, you should be closer to 14 volts when the system is charging, and if it dies when the battery is diconnected that means it isn't charging.
#89521 05/17/2005 5:25 PM
Junior Member
Junior Member
Thanks for the replies guys. Thats what I was thinking. Question, does the voltage regulator have anything to do with the generator charging? Also, can I test to see if the generator is putting anything out ? Where do put my probes from my meter ?
Thanks again, Jason
#89522 05/17/2005 9:55 PM
Junior Member
Junior Member
I just installed an alternator on the engine. Works great.
Thanks, Jason
#89523 05/18/2005 1:10 AM
H Online: Content
One precaution, PLEASE don't remove that battery cable to see if the alternator is charging! The rectifier diodes, and the internal voltage regulator, if it's got one, won't stand much of that. I'm sure you've already done that at least once, or you wouldn't be telling us it works!
The solid-state diodes and transistors, etc., don't like voltage surges, and I've seen spikes of 100 volts or more when a cable is removed while an engine is running. Check the running voltage with a digital voltmeter. It should be from 13.5 to 14.5 or so if the battery is well-charged. Against a low battery, the voltage will be around 13.25 volts or slightly less, and the current output will be 40 amps or more. As the battery builds up, the current drops, and the voltage rises.
#89524 05/18/2005 12:27 PM
Junior Member
Junior Member
I am looking for the pig tails that go into the back of the tail light houseing on my 59 fleetside. They are the plug in type that twist lock with spring loaded ends(just like the 1157 bulb) I cannot find them anywhere. Is there a retro fit I can use? Please any suggestions will help!
Thanks ,,Brad
#89525 05/18/2005 12:54 PM
Chevy Duty has them for $4.95ea
